OpenMultiboot
eydunp
Hi!
Have recently switched from BH 3.0.1.F to OBH 0.4
After installing the old image on OBH 0.4 OpenMultiboot, I can not find the "OpenMultiboot" plugin in the green panel anymore. What I´m i missing??
Wher do I find the plugin so I can install some more images in OpenMultiboot?
Hi!
Open Multiboot plugin should be acessible "normally" via plugins browser. If it's not try this:
Press on your RCU:
<GREEN>; <YELLOW>; choose <Addons Download Manager>; choose <BlackHole Feeds Plugins>; <Extensions>:
Drop down on the plugins list, and install it.
Reboot your STB and try if the plugin Open Multiboot figures in Plugins Browser.
If so, proceed normally to install your Images in Multiboot.
Hi again!!
Thanks for the answer, but I had allready been there looking, but somehow still in the Extensions the OpenMultiboot plugin was missing.
I probably should have dug deeper into the problem to figure this one out, but i went the easy way, and flashed a week old image i had, so it´s back.
It's very easy.
1) blue panel (press 2 times blue botton)
2) open the first (in italian OTTIMIZZAZIONE BLACK HOLE)
3) scroll down and swap Openmultiboot to ENABLE
It's very easy.
Was an outdated post, from April 7, 2016. We are in 2017.
