OpenViX 3.0-753 AVAILABLE NOW
OpenViX-Enigma2 GIT CHANGELOG
openvix: build 753
openvix: build 752
openvix: build 751
[UserInterface] allow hiding of piconbg.
[AutoRes] add new feature still in tests. to enable turn it on in A/V Settings.
add UE/SE plus support.
Merge remote-tracking branch 'pli/master'
Change some wordings in setup.xml
Channelselection: Only confirm remove entry when shortcut is used
[LocationBox] fix typo from previous commit.
Swedish translation update
Update Latvian translation
Updated de.po for commit dd94a649386ca00eeafd2787de01b40e58353a6f (with correction in commit 2e049fe15891b2066c632d12b7b2c4dd0bc2bdbb)
[ServiceScan] add title and allow the number of rows to be determined by the height of the widget in the skin.
Make reverse bouquet buttons also configurable.
Fix GSOD when changing channel in timer entry
ChannelSelection: Are you sure.... is a question
[LocationBox] add missing import.
[Extensions] stop building MediaPlayer as it is no longer required.
Fix cuts file generation for timeshift recordings
ChannelSelection: Add some (shortcut) number actions
[SystemPlugins] tweak some defaults.
[UsageConfig] 'Keep focus on current service while entering servicelist' enable by default.
ChannelSelection: Reverse bouquet up down
VirtualKeyBoard: fix some GSODs with some pluging
Update de.po file - Reformatting without wrapping - Some minor corrections - Includes commit c74f170af5263d5d9ef21315d88c944f8be81f75
[ChannelSelection] fix possible BSOD when add a timer from scratch.
OE-ALLIANCE GIT CHANGELOG
openvix: build 753
[dvb-usb-af9035] add new firmware to depends.
openvix: build 752
Merge branch 'master' of ssh://github.com/oe-alliance/oe-alliance-core
[openwebif] update
openvix: build 751
Backup File deletet.... sorry
[3rd Party Feed] Update some Plugins
[oe-alliance-drivers] fix build.
[oe-alliance-drivers] start new BB for device driver's that should be pre-installed into images.
[3rd-party] update
Revert "[gigablue] se/ue plus update drivers 13.10.2013"
[ixuss] update driver 11.10.2013
[3rd Party Feed] Update (reverse-merged from commit 67c4521cc4ffd5b281f5428af1535fd6e878acc0)
[ebox] update 3g modems
[oe-alliance-wifi] add driver to quad image for usb gigabit network device.
[Plugins not wanted OpenHDF] Update
disable enigma2-plugin-extensions-partnerbox on some distro´s
[inihdp] fix case
add gigablue channel settings
* Add a proper fix for DTS Passthrough
[dreambox] update drivers 01.10.2013
* Fix non working cdfs kernel modul for >3.8 kernels
Images can be downloaded directly from the OpenViX server ( Link Below )
or via a online update
menu> setup> software update.
or via a telnet session with the following command
init 4 && opkg update && opkg upgrade && init 6
