OpenVPN does not reconnect after loosing connection (OpenBH 0.4)
ricky88
Hi,
I've got OpenVPN set up with my Solo SE. It works fine for a couple of hours. I can even switch the box off and on, and it still works (top-right STB button).
However, when I turn the STB on the day after, the connection is not established and it uses my regular IP address. I need to restart OpenVPN in order for it to connect again.
Is it possible to make it reconnect automatically when it detects that the connection is lost? Would be a nice security feature.
add the following line to your client config:
keepalive 10 60
if it won't help I'll need to see your client config. Obviously without your credentials
