OpenVPN wont start - openBH 0.4 SoloSE
ricky88
Hi,
I am trying to start OpenVPN, but it wont work.
When I push the orange button (Set Active) I recieve the message: "OpenVPN Enabled. Autostart activated."
Then, when I push the red button (Start), it says: "You have to activate OpenVPN before to start".
Also, after I push the orange button, Startup Module on the main screen still says: Inactive
The OpenVPN log is empty.
Any suggestions? Is it possible to make it auto-start manually?
Thanks
Tried to run OpenVPN manually: openvpn /etc/openvpn/client.conf
Recieved the following error: Cannot open TUN/TAP dev /dev/net/tun: No such file or directory (errno=2)
Thank you.
This is my first time using OpenBH. Where in OpenBH can I update the image?
Setup -> Software management -> software-update?
