openvpn
hi ,
please help how I can install openvpn in my vu+ultimo ....
urgent
awaiting for your answers
regards
OpenVPN is already installed if you use BH images.
You should (only) configure it as your needs: there are some tutorials on the web to do this step.
please give link , how I can configure openvpn
I've openvpn files and I don't know how I put them in my box
thx a lot
thx a lot
If your already have config files, you should put config files in /var/etc/openvpn and usually .crt or .key files in /var/etc/openvpn/keys depending on what you have in config files.
Then you should start openvpn in blue panel (click twice blue botton)
