OpenWebIf OpenPli 6.1
___RomanO___
Hello,
I did a mistake and uninstalled openwebif plugin and impossible now to reinstall it from plugin manager or *******, i always get a download error.
Someone knows where can i get the ipk and how to reinstall it manually?
Thanks.
Hello,
Thanks.
By telnet run the following commands:
opkg install enigma2-plugin-extensions-openwebif
killall -9 enigma2
NOTE PLEASE:
This kind of pannels you are referring on your post are not welcome on our board
Thanks Nunigaia for your reply and sorry for the reference, i did not know :unsure:
This command does not work, i got a "wget : server returned error : HTTP/1.1 404 Not Found" for each element...
Collected errors:
 * opkg_download_backend: Failed to download http://downloads.openpli.org/feeds
openpli-6.1-rc/mips32el/python-cheetah_2.4.4-r3.0_mips32el.ipk, wget returned 1
 * opkg_install_pkg: Failed to download python-cheetah. Perhaps you need to run
'opkg update'?
openpli-6.1-rc/mips32el/python-misc_2.7.12-r1.0_mips32el.ipk, wget returned 1.
 * opkg_install_pkg: Failed to download python-misc. Perhaps you need to run 'o
kg update'?
openpli-6.1-rc/mips32el/python-unixadmin_2.7.12-r1.0_mips32el.ipk, wget returne
 1.
 * opkg_install_pkg: Failed to download python-unixadmin. Perhaps you need to r
n 'opkg update'?
openpli-6.1-rc/vusolose/enigma2-plugin-extensions-openwebif_1+git2909+07a77f7-r
.0_vusolose.ipk, wget returned 1.
 * opkg_install_pkg: Failed to download enigma2-plugin-extensions-openwebif. Pe
haps you need to run 'opkg update'?
 * opkg_solver_install: Cannot install package enigma2-plugin-extensions-openwe
if.
Collected errors:
'opkg update'?
kg update'?
1.
n 'opkg update'?
if.
Sorry mate, but you are in BlackHole image section and i thought that you are using BlackHole image, but you are not.
You are using OpenPli image, though you must ask for support on OpenPli board.
In any case, try run first this comands:
opkg update && opkg upgrade
reboot
If all suceeded, run then:
killall -9 enigma2
Note: As this space is only for BlackHole images, you are here :offtopic:
Hello,
Collected errors:
'opkg update'?
kg update'?
1.
n 'opkg update'?
if.
Thanks.
Hi,
I suppose @nunigaia meant it was better to ask in the OpenPli forum... ;)
I don't use OpenPli because I had been trying it for a while sometimes in the past but it's too ugly for my tastes. But, as it is an open project like our OpenBlackHole, you should find OWIF under the plugins, in the EXTENSION section.
Just you are here, may I suggest you to give a try to our OBH? ;) I'm sure you'll be glad to meet her...
Hello,
The problem, i think, you are using a OpenPli image 6.1 release candidate ( rc ) ... " openpli-6.1-rc ", and probably the feeds are turned off.
So you have no feeds. The better way to solve the issue is to reflash your STB with a new image.
If you know BlackHole team images, you can give a try to BlackHole 3.0.6 or Open BlackHole 4.2 image, and then you have support here in our board. If you intend not to do it, please ask on OpenPli board:
https://forums.openpli.org/
Hello, help,
anyone can we send plugin 3G modem manager "ipk" to OpenPli?
I can download VU+solo2.
Could you provide me the plugin for manual installation (ipk file for OpenPli 6.0 Vu+ Solo2), i dont have internet connexion.
Thank you and best regards
Hello, help,
Dear NM1
I have seen your POST at OPli forum...just wait for their reply.
Regards,
a911
