Openwebif remote buttons problem
Lateron
I have a VU+ Duo with Black Hole image 2.0.8.1 and have a problem with the Openwebif plugin. I can do everything with it except use the Menu, Exit, Ok and colour buttons. on previous versions of BJ image everything worked OK. Is there something I have forgotten or is there another update? Somewhere on the site it was suggested to manually update openwebif, which I did without any difference.(
I used Openwebif_200120110_bh.tgz
Any advice will be appreciated.
