Is it possible to access TV channels (openwebif) remotely from a different ip?
What do you mean by more dedicated angelo?I think YES, but you should be more dedicated about your needs.
Cool ty I will looking to it... My router only allows to open one port per IP address. So it means I can't do it. Thanks though.I explain better what I mean.
If you want to see your TV programs on your LAN (or WLAN) it's not a problem.
If you want to see your TV programs via Internet, you need a good upload speed, a Dyndns account if your ISP has dynamic IP assegnation and forward 80, 8001 and 8002 TCP ports from your router to your box.
