carwash Vu+ Newbie Feb 24, 2013 #1 I'm trying to make Openwebif secured and just need some guide 1) On Http port can I use port of my choice or do I have to use default one? 2) Again with Https! can it be the same port or leave on default? Regards
angelofsky1980 BlackHole Driver Specialist Feb 24, 2013 #2 carwash said: I'm trying to make Openwebif secured and just need some guide 1) On Http port can I use port of my choice or do I have to use default one? 2) Again with Https! can it be the same port or leave on default? Regards Click to expand... You can use a port you like without problems.
carwash Vu+ Newbie Feb 24, 2013 #3 angelofsky1980 said: You can use a port you like without problems. Click to expand... thank you!
