Openwebif streaming problem and XBMC issues
Astronyu
Guys, I need some help regarding Vu Solo2 openwebif problem.
My problems:
1- Openwebif (solo2 standby mode)
- I can stream on port 8001
- I cannot stream on port 8002 (transcoding)
2- Openwebif (solo2 on mode)
- I can only stream same channel playing (zap off; port 8001)
- I can stream any channels but will also change channel on tv (zap on; port 8001)
3- XBMC
- I receives bouquet and channel list but when selecting any channels, nothing plays.
Please note that I can verify transcoding and streaming works fine as tested from within VU+ Player which I tweaked the setting of bitrate and framerate for the transcoding so that I could watch 1 channel on TV and watch another channel on vu player.
Info:
Kernel version: 3.3.8
Firmware version: BlackHole 2.1.0
Gui version: 2014-05-28-master
@Astronyu : You can't view two different channels with only one sat input.
You have to have two independent sat signals coming to your box.
Oh, I see. So, I have to rely on the transcoding if I want to watch different channel from what is been playing then or have the unit turned off before I stream it elsewhere then I guess.
