Original Teletext Function
AlexWilMac
Moderator
Hello,
I bought my VU+Duo2 already equipped with BH 2.1.4 and there was the TuxTxt plugin installed.
I'd like to see how the receiver work without this plugin but I haven't found the way to uninstall. I don't find it neither in Plugins nor in BlackHole panel, unless it is listed with a different name.
I tried also to remove the files from the box but this way I get and error message when I press the Teletext button.
As I had copied the plug-in folder, I was able to copy it back and now TuxTxt works again.
But how uninstall it properly?
Hello,
See this post, by SHIRO, maybe it will help you!
http://www.vuplus-community.net/board/threads/bh-2-1-0-online-update.17974/#post-137449
