Original VU+ bootlogos
AlexWilMac
Moderator
Hello,
I've bought a VU+ with BH 2.1.4 but the bootlogos are neither the original VU+ ones nor the BH ones and I don't like them. Where can I find the original VU+ ones?
Thanks
You are right... I forgot to say I've got a VU+Duo2. Anyway, I finally found the original bootlogos. So I put:
- Bootlogo.mvi (start image without text)
- Backdrop.mvi (start screen that is shown when loading the settings "loading ...")
- Bootlogo_wait.mvi (start screen with "please wait ...)
- Reboot.mvi (start screen for restart)
- Shutdown.mvi (image for shutdown)
- Radio.mvi (image for radio reception)
in the /usr/share folder. But if I perform a deep restart there are still two personalised screen different from all the ones above. As I don't have a MVI reader is not easy to explore all the folders (taken that they are .mvi files as well...). Where should I look?
You have presume BLACKHOLE one ( Black ) ?
You cannot change this cause it´s on the bin bootloader version 2 and it´s i think hardcoded.
I have BH 2.1.4 but the first two pictures are not from BH because there's the name of the guy who patched it.
