OSD position
TV image size can not be changed in OBH.
It may be possible to use UIPositionSetup as i Blackhole to have possibility to change TV image size.
I have not test.
For @Thomas67
doe not use Black Hole skins in Open Black Hole
because it generates a lot of errors in the image even though you do not see it.
I have not test.
For @Thomas67
I did it
and it works!
Only one thing....as you can see from the attachment the skin to setup is different from OBH
