OSD's menu position: suggestion
Would you move OSD position directly within User interface menu?
  • Total voters
    2
AlexWilMac
Moderator
It's always difficult (if I don't use this function for a while) to find the submenu where you can resize or move the OSDs frames.
If you don't remember where a command is, you try to follow a logical way to it.
In OBH this function is under
Setup/User interface/Skin setup/OSD position
Now, yes, skin setup might be the right section but the word "skin" itself, I believe, is a little bit misleading.
Why not moving the OSD position one level up, directly within USER INTERFACE?
What do you think, coders, of that?
