Pauli- Neutrino for BH 1.7.2
Don Andres
BH Lover
If anyone has latest Pauli Neutrino plugin for BH 1.7.2 in bh.tgz or ipk format , please PM it to me.
I would like to test it with Black Pole image .
Not working unfortunatelly :(
Plugin is innstaling without a problem , but when one try to change keymap to Neutrino ( yellow button ) - green crash logg appears , see below :
<?xml version="1.0" encoding="utf-8"?>
<openpli>
<enigma2>
<crashdate>fr. april 6 16:34:12 2012</crashdate>
<compiledate>Apr 5 2012</compiledate>
<contactemail>forum at www.openpli.org</contactemail>
<skin>skin.xml</skin>
<sourcedate>Apr 5 2012</sourcedate>
<branch>(no branch)</branch>
<rev></rev>
<version>3.0.0</version>
</enigma2>
<image>
<stbmodel>duo</stbmodel>
<kernelversion>
<![CDATA[
Linux vuduo 3.1.1 #1 SMP Mon Apr 2 20:11:18 CEST 2012 mips GNU/Linux
</kernelversion>
<kernelcmdline>bmem=112M ubi.mtd=0 root=ubi0:rootfs rootfstype=ubifs rw rootflags=sync bmem=112M</kernelcmdline>
<imageversion>
<!-- No such file or directory -->
</imageversion>
<imageissue>
<![CDATA[
OpenEmbedded Linux %h
BlackPole 0.1.2 %h
</imageissue>
</image>
<crashlogs>
<enigma2crashlog>
<![CDATA[
+ (1) Background File Eraser
+ (5) Tuxtxt
+ (8) graphics acceleration manager
+ (9) GFBDC
12150k video mem
- double buffering available!
5670kB available for acceleration surfaces.
resolution: 720 x 576 x 32 (stride: 5760)
+ (9) gLCDDC
found OLED display!
lcd buffer 0x6e26f0 8448 bytes, stride 132
+ (9) Font Render Class
[FONT] initializing lib...
[FONT] loading fonts...
[FONT] Intializing font cache, using max. 4MB...
+ (10) gRC
RC thread created successfully
+ (15) eWindowStyleManager
+ (20) DVB-CI UI
+ (20) UHF Modulator
couldnt open /dev/rfmod0!!!!
+ (20) RC Input layer
+ (20) misc options
+ (20) AVSwitch Driver
couldnt open /dev/dbox/fp0 to monitor vcr scart slow blanking changed!
+ (21) input device driver
Input device "dreambox advanced remote control (native)" is a mouse
Found 1 input devices!
+ (22) Hdmi CEC driver
+ (30) eActionMap
+ (35) CI Slots
scanning for common interfaces..
CI Slot 0 setSource(0)
CI Slot 1 setSource(0)
eDVBCIInterfaces->setInputSource(0, 0)
eDVBCIInterfaces->setInputSource(1, 1)
cannot open /proc/stb/tsmux/input2
cannot open /proc/stb/tsmux/input3
done, found 2 common interface slots
+ (35) CA handler
+ (36) Stream server
+ (40) eServiceCenter
settings instance.
+ (41) eServiceFactoryDVD
+ (41) eServiceFactoryM2TS
+ (41) eServiceFactoryMP3
+ (41) eServiceFactoryFS
+ (41) eServiceFactoryDVB
reached rl 70
---- opening lame channel db
reading services (version 4)
loaded 5499 services
scanning for frontends..
opening frontend 0
detected satellite frontend
close frontend 0
opening frontend 1
close frontend 1
found 1 adapter, 2 frontends(2 sim) and 5 demux, boxtype 2
RTC not ready... wait for transponder time
[EPGC] Initialized EPGCache (wait for setCacheFile call now)
Loading spinners...
found 8 spinner!
setIoPrio best-effort level 3 ok
main thread is non-idle! display spinner!
couldn't open fp
[Harddisk] enumerating block devices...
Reading satellites.xml
removing internal link on frontend id 1
sec config cleared
setSlotInfo for dvb frontend 0 to slotid 0, descr BCM7335 DVB-S2 NIM (internal), need rotorworkaround No, enabled Yes, DVB-S2 Yes
setSlotInfo for dvb frontend 1 to slotid 1, descr BCM7335 DVB-S2 NIM (internal), need rotorworkaround No, enabled Yes, DVB-S2 Yes
slot: 0 configmode: simple
diseqcmode: diseqc_a_b_c_d
slot: 1 configmode: equal
sec config completed
[ePopen] command: ip -o addr show dev eth0
loading bouquet... /etc/enigma2/bouquets.tv
loading bouquet... /etc/enigma2/userbouquet.dbe00.tv
123 entries in Bouquet userbouquet.dbe00.tv
loading bouquet... /etc/enigma2/userbouquet.dbe02.tv
114 entries in Bouquet userbouquet.dbe02.tv
loading bouquet... /etc/enigma2/userbouquet.dbe03.tv
42 entries in Bouquet userbouquet.dbe03.tv
loading bouquet... /etc/enigma2/userbouquet.dbe04.tv
87 entries in Bouquet userbouquet.dbe04.tv
loading bouquet... /etc/enigma2/userbouquet.favourites.tv
0 entries in Bouquet userbouquet.favourites.tv
loading bouquet... /etc/enigma2/userbouquet.dbe01.tv
7 entries in Bouquet userbouquet.dbe01.tv
6 entries in Bouquet bouquets.tv
loading bouquet... /etc/enigma2/bouquets.radio
loading bouquet... /etc/enigma2/userbouquet.favourites.radio
23 entries in Bouquet userbouquet.favourites.radio
1 entries in Bouquet bouquets.radio
[eDVBLocalTimeHandler] enable sync local time with transponder time!
add dreampackage scanner plugin
added
[FONT] adding font /usr/share/fonts/nmsbd.ttf...OK (Regular)
[FONT] adding font /usr/share/fonts/andale.ttf...OK (Fixed)
[FONT] adding font /usr/share/fonts/tuxtxt.ttf...OK (Console)
[FONT] adding font /usr/share/fonts/ae_AlMateen.ttf...OK (Replacement)
4050kB available for acceleration surfaces.
resolution: 1280 x 720 x 32 (stride: 5760)
[FONT] adding font /usr/share/fonts/Army_Regular_L.ttf...OK (Regular)
[FONT] adding font /usr/share/fonts/esp_0.ttf...OK (RegularAA)
[FONT] adding font /usr/share/fonts/army-digital.ttf...OK (LCD)
[FONT] adding font /usr/share/fonts/goodtime.ttf...OK (OLED)
[FONT] adding font /usr/share/fonts/nmsbd.ttf...OK (Display)
[FONT] adding font /usr/share/fonts/nmsbd2.ttf...OK (oledRegular)
[FONT] adding font /usr/share/fonts/nmsbd.ttf...OK (oledDisplay)
[FONT] adding font /usr/share/fonts/valis_enigma.ttf...OK (Subs)
[iInputDevices] getInputDevices <ERROR: ioctl(EVIOCGNAME): [Errno 25] Inappropriate ioctl for device >
Activating keymap: Default (US)
[ePopen] command: loadkmap < /usr/share/keymaps/default.kmap
Activating language Norsk
--> setting scaler_sharpness to: 0000000D
couldn't open /proc/stb/misc/12V_output
[SETTING] getFlushSize= 0
setLCDBrightness 25
setLCDBrightness 127
FIXME: request for unknown slot
[AutoBackup] fallback to default translation for Automatic settings backup
/usr/lib/python2.6/site-packages/twisted/spread/pb.py:30: DeprecationWarning: the md5 module is deprecated; use hashlib instead
/usr/lib/python2.6/site-packages/twisted/python/filepath.py:12: DeprecationWarning: the sha module is deprecated; use the hashlib module instead
Plugin Extensions/WebInterface failed to load: No module named plugin
Plugin probably removed, but not cleanly in /usr/lib/enigma2/python/Plugins/Extensions/WebInterface
[AudioSync] set language to no
[CrossEPG] set language to no
[UIPositionSetup] write dst_left : 0
[UIPositionSetup] write dst_width : 720
[UIPositionSetup] write dst_top : 0
[UIPositionSetup] write dst_height : 576
[NetworkBrowser] set language to no
[NetworkBrowser] fallback to default translation for NetworkBrowser
[NetworkBrowser] fallback to default translation for Search for network shares
[NetworkBrowser] fallback to default translation for MountManager
[NetworkBrowser] fallback to default translation for Manage network shares
[NetworkBrowser] fallback to default translation for Mount again
[NetworkBrowser] fallback to default translation for Attempt to mount shares again
getModeList for port DVI-PC
getModeList for port YPbPr
getModeList for port Scart
hotplug on dvi
-> setting aspect, policy, policy2, wss 16:9 panscan letterbox auto
setMode - port: DVI mode: 720p rate: multi
starting hotplug handler
[PAULI] currently no autostart
[SKIN] Parsing embedded skin <embedded-in-'PauliStartup'>
[EPGC] setCacheFile read/write epg data from/to '/usr/crossepg/data/epg.dat'
not showing fine-tuning wizard, config variable doesn't exist
showtestcard is false
[SKIN] Parsing embedded skin <embedded-in-'Dummy'>
setValue 50
Setvolume: 100 100 (raw)
Setvolume: 0 0 (-1db)
Setvolume: 50 50 (raw)
Setvolume: 32 32 (-1db)
warning, skin is missing element From in <class 'Screens.Dish.Dish'>
warning, skin is missing element Goto in <class 'Screens.Dish.Dish'>
warning, skin is missing element posGoto in <class 'Screens.Dish.Dish'>
warning, skin is missing element posFrom in <class 'Screens.Dish.Dish'>
warning, skin is missing element turnTime in <class 'Screens.Dish.Dish'>
RemovePopup, id = ZapError
child has terminated
pipes closed
pipes closed
[ePopen] command: route -n | grep eth0
poll: unhandled POLLERR/HUP/NVAL for fd 34(16)
poll: unhandled POLLERR/HUP/NVAL for fd 36(16)
playing 1:0:1:412:46:46:E080000:0:0:0:
not pauseable.
allocate channel.. 0046:0046
opening frontend 0
(0)tune
RotorCmd ffffffff, lastRotorCmd ffffffff
prepare_sat System 1 Freq 10747000 Pol 1 SR 25000000 INV 2 FEC 3 orbpos 3592 system 1 modulation 2 pilot 2, rolloff 1
tuning to 997 mhz
OURSTATE: tuning
allocate Channel: res 0
[eDVBCIInterfaces] addPMTHandler 1:0:1:412:46:46:E080000:0:0:0:
allocate demux
pipes closed
0.0.0.0
169.254
192.168
nameservers: [[10, 0, 0, 138]]
read configured interface: {'bnep0': {'dhcp': True}, 'usb0': {'dhcp': False}, 'lo': {'dhcp': False}, 'usbd0': {'dhcp': False}, 'usbf': {'dhcp': False}, 'wlan0': {'dhcp': True}, 'atml0': {'dhcp': True}, 'eth1': {'dhcp': True}, 'eth0': {'dhcp': True}}
self.ifaces after loading: {'eth0': {'preup': False, 'predown': False, 'ip': [192, 168, 1, 103], 'up': True, 'mac': '00:1d:ec:02:8d:f2', 'dhcp': True, 'netmask': [255, 255, 255, 0], 'gateway': [192, 168, 1, 1]}}
[OpenWebif] loading external plugins...
[OpenWebif] no plugins to load
[OpenWebif] started on 80
poll: unhandled POLLERR/HUP/NVAL for fd 33(16)
[SEC] set static current limiting
set sequence pos 3
set sequence pos 4
[SEC] setVoltage 1
[SEC] sleep 200ms
[SEC] invalidate current switch params
[SEC] sendDiseqc: e00000(DiSEqC reset)
[SEC] sleep 50ms
[SEC] sendDiseqc: e00003(DiSEqC peripherial power on)
[SEC] sleep 150ms
[SEC] sendDiseqc: e01038f0
[SEC] sleep 50ms
set sequence pos 3
set sequence pos 3
[SEC] update current switch params
[SEC] startTuneTimeout 5000
[SEC] setFrontend 1
setting frontend 0
(0)fe event: status 0, inversion off, m_tuning 1
[SEC] sleep 500ms
(0)fe event: status 1f, inversion on, m_tuning 2
OURSTATE: ok
[eDVBLocalTimerHandler] channel 0x1803c98 running
[eEPGCache] channel 0x1803c98 running
stop release channel timer
ok ... now we start!!
eventNewProgramInfo 0 0
have 1 video stream(s) (0200), and 1 audio stream(s) (0280), and the pcr pid is 0200, and the text pid is 0240
allocate demux
decoder state: play, vpid=512, apid=640
DMX_SET_PES_FILTER(0x200) - pcr - ok
DEMUX_START - pcr - ok
DMX_SET_PES_FILTER(0x280) - audio - ok
DEMUX_START - audio - ok
AUDIO_SET_BYPASS(1) - ok
AUDIO_PAUSE - ok
AUDIO_PLAY - ok
Video Device: /dev/dvb/adapter0/video0
demux device: /dev/dvb/adapter0/demux0
VIDEO_SET_STREAMTYPE 1 - ok
DMX_SET_PES_FILTER(0x200) - video - ok
DEMUX_START - video - ok
VIDEO_FREEZE - ok
VIDEO_PLAY - ok
DMX_SET_PES_FILTER(0x240) - ttx - ok
DEMUX_START - ttx - ok
VIDEO_SLOWMOTION(0) - ok
VIDEO_FAST_FORWARD(0) - ok
VIDEO_CONTINUE - ok
AUDIO_CONTINUE - ok
AUDIO_CHANNEL_SELECT(0) - ok
disable teletext subtitles
not pauseable.
[SEC] set dynamic current limiting
[eDVBLocalTimerHandler] dont have correction.. set Transponder Diff
[eDVBLocalTimerHandler] update RTC
[eDVBLocalTimerHandler] time update to 16:33:25
[eDVBLocalTimerHandler] m_time_difference is 1333722761
[eDVBLocalTimerHandler] set Linux Time
[EPGC] time updated.. start EPG Mainloop
VIDEO_GET_EVENT - ok
[EPGC] next update in 2 sec
PATready
use pmtpid 0105 for service_id 0412
[eDVBCAService] new service 1:0:1:412:46:46:E080000:0:0:0:
[eDVBCAService] add demux 0 to slot 0 service 1:0:1:412:46:46:E080000:0:0:0:
[eDVBCIInterfaces] gotPMT
demux 0 mask 01 prevhash 0
sdt update done!
[EPGC] start caching events(1333722807)
[EPGC] abort non avail schedule reading
[EPGC] abort non avail schedule other reading
[EPGC] abort non avail netmed schedule reading
[EPGC] abort non avail netmed schedule other reading
[EPGC] abort non avail FreeSat schedule_other reading
[EPGC] abort non avail viasat reading
[EPGC] nownext finished(1333722814)
[EPGC] stop caching events(1333722814)
[EPGC] next update in 60 min
action -> InfobarSubserviceSelectionActions DeliteGpshow
action -> WizardActions right
unknown action WizardActions/right! typo in keymap?
action -> WizardActions ok
[SKIN] Parsing embedded skin <embedded-in-'Pauli'>
[SKIN] Parsing embedded skin <embedded-in-'PauliRemoteControlSetup'>
action -> ShortcutActions yellow
File "/usr/lib/enigma2/python/Components/ActionMap.py", line 46, in action
File "/usr/lib/enigma2/python/Plugins/Extensions/Pauli/plugin.py", line 604, in setNeutrino
ibgfile = open(pauli_infobar, "r")
IOError: [Errno 2] No such file or directory: '/usr/lib/enigma2/python/Screens/InfoBarGenerics.py'
(PyObject_CallObject(<bound method ActionMap.action of <Components.ActionMap.ActionMap instance at 0x174ac10>>,('ShortcutActions', 'yellow')) failed)
</enigma2crashlog>
</crashlogs>
</openpli>
Sorry , transfering infoBarGeneric.pyo didn't help at all .
The crash log ask to post a thread to " open pli forum " :
<openpli>
<enigma2>
<crashdate>fr. april 6 18:17:42 2012</crashdate>
<rev></rev>
</enigma2>
<image>
<stbmodel>ultimo</stbmodel>
<kernelversion>
<![CDATA[
Linux vuultimo 3.1.1 #1 SMP Sat Feb 4 18:18:22 CET 2012 mips GNU/Linux
</kernelversion>
<kernelcmdline>bmem=232M ubi.mtd=0 root=ubi0:rootfs rootfstype=ubifs rw rootflags=sync</kernelcmdline>
<imageversion>
</imageversion>
<imageissue>
<![CDATA[
BlackPole 0.1.2 %h
</imageissue>
</image>
<crashlogs>
<enigma2crashlog>
<![CDATA[
uet... /etc/enigma2/userbouquet.13_0e_erotic.tv
21 entries in Bouquet userbouquet.13_0e_erotic.tv
loading bouquet... /etc/enigma2/userbouquet.13_0e_free.tv
60 entries in Bouquet userbouquet.13_0e_free.tv
loading bouquet... /etc/enigma2/userbouquet.9_0e_eurobird_9.tv
22 entries in Bouquet userbouquet.9_0e_eurobird_9.tv
loading bouquet... /etc/enigma2/userbouquet.9_0e_platforma_hd.tv
37 entries in Bouquet userbouquet.9_0e_platforma_hd.tv
loading bouquet... /etc/enigma2/userbouquet.7_0e_digiturk.tv
163 entries in Bouquet userbouquet.7_0e_digiturk.tv
loading bouquet... /etc/enigma2/userbouquet.5_0e_sirius.tv
22 entries in Bouquet userbouquet.5_0e_sirius.tv
loading bouquet... /etc/enigma2/userbouquet.5_0e_viasat_hd.tv
20 entries in Bouquet userbouquet.5_0e_viasat_hd.tv
loading bouquet... /etc/enigma2/userbouquet.5_0e_viasat_swe.tv
32 entries in Bouquet userbouquet.5_0e_viasat_swe.tv
loading bouquet... /etc/enigma2/userbouquet.5_0e_viasat_den.tv
22 entries in Bouquet userbouquet.5_0e_viasat_den.tv
loading bouquet... /etc/enigma2/userbouquet.5_0e_viasat_all.tv
51 entries in Bouquet userbouquet.5_0e_viasat_all.tv
loading bouquet... /etc/enigma2/userbouquet.3_1e_al_jazeera.tv
10 entries in Bouquet userbouquet.3_1e_al_jazeera.tv
loading bouquet... /etc/enigma2/userbouquet.0_8w_cd_swe.tv
33 entries in Bouquet userbouquet.0_8w_cd_swe.tv
loading bouquet... /etc/enigma2/userbouquet.0_8w_cd_den.tv
23 entries in Bouquet userbouquet.0_8w_cd_den.tv
loading bouquet... /etc/enigma2/userbouquet.0_8w_upc.tv
66 entries in Bouquet userbouquet.0_8w_upc.tv
loading bouquet... /etc/enigma2/userbouquet.0_8w_upc_cz.tv
23 entries in Bouquet userbouquet.0_8w_upc_cz.tv
loading bouquet... /etc/enigma2/userbouquet.0_8w_upc_slo.tv
8 entries in Bouquet userbouquet.0_8w_upc_slo.tv
loading bouquet... /etc/enigma2/userbouquet.0_8w_upc_ro.tv
79 entries in Bouquet userbouquet.0_8w_upc_ro.tv
loading bouquet... /etc/enigma2/userbouquet.1_0w_digitv_ro.tv
37 entries in Bouquet userbouquet.1_0w_digitv_ro.tv
loading bouquet... /etc/enigma2/userbouquet.1_0w_digi_tv_hu.tv
30 entries in Bouquet userbouquet.1_0w_digi_tv_hu.tv
loading bouquet... /etc/enigma2/userbouquet.1_0w_digi_tv_se_h.tv
14 entries in Bouquet userbouquet.1_0w_digi_tv_se_h.tv
loading bouquet... /etc/enigma2/userbouquet.1_0w_digi_tv_czsl.tv
29 entries in Bouquet userbouquet.1_0w_digi_tv_czsl.tv
loading bouquet... /etc/enigma2/userbouquet.1_0w_digi_tv_.tv
44 entries in Bouquet userbouquet.1_0w_digi_tv_.tv
loading bouquet... /etc/enigma2/userbouquet.4_0w_amos.tv
22 entries in Bouquet userbouquet.4_0w_amos.tv
loading bouquet... /etc/enigma2/userbouquet.5_0w_atl_bird3.tv
63 entries in Bouquet userbouquet.5_0w_atl_bird3.tv
loading bouquet... /etc/enigma2/userbouquet.7_0w_nilesat.tv
21 entries in Bouquet userbouquet.7_0w_nilesat.tv
loading bouquet... /etc/enigma2/userbouquet.30_0w_digital_.tv
95 entries in Bouquet userbouquet.30_0w_digital_.tv
loading bouquet... /etc/enigma2/userbouquet.30_0w_tv_cabo.tv
112 entries in Bouquet userbouquet.30_0w_tv_cabo.tv
loading bouquet... /etc/enigma2/userbouquet.30_0w_meo.tv
86 entries in Bouquet userbouquet.30_0w_meo.tv
loading bouquet... /etc/enigma2/userbouquet.23_5e_cd.tv
62 entries in Bouquet userbouquet.23_5e_cd.tv
loading bouquet... /etc/enigma2/userbouquet.23_5e_cs_link.tv
46 entries in Bouquet userbouquet.23_5e_cs_link.tv
loading bouquet... /etc/enigma2/userbouquet.23_5e_skylink.tv
54 entries in Bouquet userbouquet.23_5e_skylink.tv
loading bouquet... /etc/enigma2/userbouquet.26_0e_arabsat.tv
33 entries in Bouquet userbouquet.26_0e_arabsat.tv
loading bouquet... /etc/enigma2/userbouquet.28_2e_sky_uk.tv
162 entries in Bouquet userbouquet.28_2e_sky_uk.tv
loading bouquet... /etc/enigma2/userbouquet.31_5e_astra_1g.tv
21 entries in Bouquet userbouquet.31_5e_astra_1g.tv
loading bouquet... /etc/enigma2/userbouquet.39_0e_hellas.tv
7 entries in Bouquet userbouquet.39_0e_hellas.tv
loading bouquet... /etc/enigma2/userbouquet.42_0e_turksat.tv
57 entries in Bouquet userbouquet.42_0e_turksat.tv
loading bouquet... /etc/enigma2/userbouquet.45_0e_is_12.tv
21 entries in Bouquet userbouquet.45_0e_is_12.tv
loading bouquet... /etc/enigma2/userbouquet.53_0e_express.tv
19 entries in Bouquet userbouquet.53_0e_express.tv
loading bouquet... /etc/enigma2/userbouquet.75_0e_raduga_tv.tv
85 entries in Bouquet userbouquet.75_0e_raduga_tv.tv
loading bouquet... /etc/enigma2/userbouquet.LastScanned.tv
0 entries in Bouquet userbouquet.LastScanned.tv
loading bouquet... /etc/enigma2/userbouquet.not_possible.tv
237 entries in Bouquet userbouquet.not_possible.tv
73 entries in Bouquet bouquets.tv
0 entries in Bouquet userbouquet.favourites.radio
added
[FONT] adding font /usr/share/fonts/nmsbd.ttf...OK (FdLcD)
[FONT] adding font /usr/share/fonts/analog.ttf...OK (VFD)
cannot open /proc/stb/avs/0/input_choices
setLCDBrightness 25
[MeoBoot] set language to no
[Picon] adding path: /media/hdd/picon/
[Picon] adding path: /media/sdb1/picon/
<ManualFancontrol> setPWM to : 100
<ManualFancontrol> init : self.fanoffmode : OFF
<ManualFancontrol> init : config.plugins.manualfancontrols.pwmvalue.value : 100
hotplug on dvi
-> setting aspect, policy, policy2, wss 16:9 bestfit bestfit auto
<RemoteControlCode> Write Remote Control Code : 2
[EPGC] setCacheFile read/write epg data from/to '/hdd/epg.dat'
setValue 10
Setvolume: 10 10 (raw)
Setvolume: 57 57 (-1db)
[SKIN] No skin to read...
pipes closed
pipes closed
cidr invalid: 64
pipes closed
poll: unhandled POLLERR/HUP/NVAL for fd 38(17)
playing 1:0:1:157E:C92:3:EB0000:0:0:0:
not pauseable.
allocate channel.. 0c92:0003
opening frontend 0
(0)tune
Entry for 23,5? not in Rotor Table found... i try gotoXX?
siteLatitude = 60.516998, siteLongitude = 8.200000, 23.500000 degrees
PolarmountHourAngle=163.490811
RotorCmd = e108
RotorCmd e108, lastRotorCmd ffffffff
set rotor timeout to 360 seconds
prepare_sat System 1 Freq 12051000 Pol 1 SR 27500000 INV 2 FEC 3 orbpos 235 system 1 modulation 2 pilot 2, rolloff 0
tuning to 1451 mhz
OURSTATE: tuning
[eDVBCIInterfaces] addPMTHandler 1:0:1:157E:C92:3:EB0000:0:0:0:
allocate demux
pipes closed
0.0.0.0
169.254
192.168
read configured interface: {'lo': {'dhcp': False}, 'eth0': {'dhcp': False, 'netmask': [255, 255, 255, 0], 'gateway': [192, 168, 1, 1], 'address': [192, 168, 1, 10]}}
self.ifaces after loading: {'eth0': {'preup': False, 'predown': False, 'ip': [192, 168, 1, 10], 'up': True, 'mac': '00:1d:ec:03:7c:31', 'dhcp': False, 'bcast': [192, 168, 1, 255], 'netmask': [255, 255, 255, 0], 'gateway': [192, 168, 1, 1]}}
set sequence pos 3
[SEC] setVoltage 1
[SEC] sleep 900ms
set sequence pos 9
[SEC] invalidate current rotorparams
[SEC] sendDiseqc: e0316ee108
[SEC] sleep 1000ms
set sequence pos 3
[SEC] setTone 1
[SEC] sleep 10ms
[SEC] setFrontend 0
setting frontend 0
[SEC] set timeout 1440
[SEC] sleep 250ms
[SEC] locked step 0 ok
set sequence pos -3
[SEC] sleep 250ms
[SEC] locked step 1 ok (305419896 305419896)
set sequence pos -3
[SEC] sleep 250ms
[SEC] locked step 2 ok (305419896 305419896)
set sequence pos -3
[SEC] sleep 250ms
[SEC] locked step 3 ok (305419896 305419896)
set sequence pos -3
[SEC] sleep 250ms
[SEC] locked step 4 ok (305419896 305419896)
ok > 4 .. goto 3
set sequence pos 3
OURSTATE: ok
[eDVBLocalTimerHandler] channel 0x1ae9e68 running
[eEPGCache] channel 0x1ae9e68 running
have 1 video stream(s) (00c9), and 1 audio stream(s) (012d), and the pcr pid is 00c9, and the text pid is ffffffff
allocate demux
decoder state: play, vpid=201, apid=301
DMX_SET_PES_FILTER(0xc9) - pcr - ok
DMX_SET_PES_FILTER(0x12d) - audio - ok
AUDIO_PAUSE - ok
AUDIO_PLAY - ok
DMX_SET_PES_FILTER(0xc9) - video - ok
VIDEO_FREEZE - ok
VIDEO_PLAY - ok
VIDEO_CONTINUE - ok
AUDIO_CONTINUE - ok
not pauseable.
[SEC] update current rotorparams 1435 e108 235
set sequence pos 4
[SEC] sleep 500ms
PATready
use pmtpid 0065 for service_id 157e
VIDEO_CONTINUE - ok
AUDIO_CONTINUE - ok
[eDVBCAService] new service 1:0:1:157E:C92:3:EB0000:0:0:0:
[eDVBCAService] add demux 0 to slot 0 service 1:0:1:157E:C92:3:EB0000:0:0:0:
sdt update done!
[eDVBLocalTimerHandler] time update to 18:14:38
[eDVBLocalTimerHandler] m_time_difference is 1333728788
[EPGC] 13308 events read from /hdd/epg.dat
[EPGC] start caching events(1333728881)
[EPGC] nownext finished(1333728888)
[EPGC] schedule finished(1333728912)
[EPGC] stop caching events(1333728912)
[CrossEPG_Auto] poll
action -> WizardActions up
unknown action WizardActions/up! typo in keymap?
action -> WizardActions down
unknown action WizardActions/down! typo in keymap?
(PyObject_CallObject(<bound method ActionMap.action of <Components.ActionMap.ActionMap instance at 0x1a751e8>>,('ShortcutActions', 'yellow')) failed)
</enigma2crashlog>
</crashlogs>
</openpli>
</enigma2crashlog>
</crashlogs>
</openpli>
That`s normal at the moment.
The file is not there!!
But it`s not normal that you`re missing this screen file, unless you deleted it yourself.
It`s standard there when you flash the image.
Hello Don Andres, the folder you show with FTP is actually not the same path the plugin is looking for python script : /usr/lib/enigma2/python/Screens/InfoBarGenerics.py
My 2 cents, Pilou.
If you install a .py file you corrupt image.
This because all files are different ad the future .pyo files of image will not work. So any fix or upgrade will fail.
This is really e newbie and wrong action
@Shiro
@Pilou
Thx alot for your time and advice , Yes I realised indeed that it is far more complicated then expected , so I give up trying for now.
