Pause A Recording
gus
Hi guys
It is possible to pause a recording, example when watching TV would like to pause during the adverts then press pause to start recording again, I can remember when I was a kid I used to be able to do this on my VHS video, it would be nice to be able on my VU+ duo
Hi guys
I don't think so. I didn't try this, but i don't remember this kind of option.
It's not possible to do what you ask...maybe with a plugin you could, but i don't know this...much better to cut adverts after redcording, with your pc and editing software ;)
Hi guys
Well,,,,;) There is away but ,,,,,,is not conventional....:lamo:!
You can push the Red Video button while recording, a list will show , then select Stop Recording, later on after the Adverts are finished , push again Red V. and Start Recoding !
this will not work I would like to be able to pause for adverts, then start recording when adverts are finished, your method would not be in one file, I want to record an hour show without the adverts, but just have on video file
maybe a plugin or in a future image update this will be possible, many thanks
