News PCSC for Vu+ Boxes
angelofsky1980
BlackHole Driver Specialist
I've recompiled PCSC libs and binaries for new images based on Kernel 3.1.1 like BH.
PCSC: 1.8.1
CCID: 1.4.5
LibUSB: 1.0.8
Ok thanks. And for the new images of vu duo is it possible to read samsung cam on c.i. Slot?
Inviato dal mio GT-I9100 usando Tapatalk
PCSC Lite 1.8.2 IPK
PCSC: 1.8.2
LibUSB: 1.0.8
CCID: 1.4.5
hi angelofsky
i installed these last drivers on my ultimo connected a pcsc device 3021/3121 restarted box but i'm receiveing an error
cannot open device 0
error reading card
any help appreciated
thanks
hi angelofsky
error reading card
thanks
On this Board the cardservers and/or emus are not supported. Read Rules.
If you need help about PCSC daemon you are welcome otherwise you should look for infos in other boards on the web.
I will try to post here a simple guides how to report problems with PCSC software suite.
could you please check my debug ... seems to be working fine
00000000 debuglog.c:265:DebugLogSetLevel() debug level=debug
00001272 configfile.l:287:DBGetReaderList() Parsing conf file: /etc/reader.conf.d
00000205 pcscdaemon.c:518:main() pcsc-lite 1.8.2 daemon ready.
00023717 hotplug_libusb.c:514:HPAddHotPluggable() Adding USB device: 3:4:0
00000470 readerfactory.c:936:RFInitializeReader() Attempting startup of OmniKey CardMan 3121 00 00 using /usr/lib/pcsc/drivers/ifd-ccid.bundle/Contents/Linux/libccid.so
00001713 readerfactory.c:826:RFBindFunctions() Loading IFD Handler 3.0
00001091 ifdhandler.c:1781:init_driver() Driver version: 1.4.5
00007709 ifdhandler.c:1798:init_driver() LogLevel: 0x0003
00000186 ifdhandler.c:1809:init_driver() DriverOptions: 0x0000
00001657 ifdhandler.c:80:IFDHCreateChannelByName() lun: 0, device: usb:076b/3021:libusb-1.0:3:4:0
00007626 ccid_usb.c:245:OpenUSBByName() ifdManufacturerString: Ludovic Rousseau (ludovic.rousseau@free.fr)
00000186 ccid_usb.c:246:OpenUSBByName() ifdProductString: Generic CCID driver
00000123 ccid_usb.c:247:OpenUSBByName() Copyright: This driver is protected by terms of the GNU Lesser General Public License version 2.1, or (at your option) any later
00011788 ccid_usb.c:506:OpenUSBByName() Found Vendor/Product: 076B/3021 (OmniKey CardMan 3121)
00000178 ccid_usb.c:508:OpenUSBByName() Using USB bus/device: 3/4
00014853 ccid_usb.c:975:get_data_rates() Got 256 data rates but was expecting 106
00000206 ccid_usb.c:993:get_data_rates() declared: 10752 bps
00000087 ccid_usb.c:993:get_data_rates() declared: 21505 bps
00000073 ccid_usb.c:993:get_data_rates() declared: 43010 bps
00000072 ccid_usb.c:993:get_data_rates() declared: 86021 bps
00000072 ccid_usb.c:993:get_data_rates() declared: 172043 bps
00000115 ccid_usb.c:993:get_data_rates() declared: 344086 bps
00000075 ccid_usb.c:993:get_data_rates() declared: 129032 bps
00000132 ccid_usb.c:993:get_data_rates() declared: 215053 bps
00000077 ccid_usb.c:993:get_data_rates() declared: 12903 bps
00000071 ccid_usb.c:993:get_data_rates() declared: 25806 bps
00000071 ccid_usb.c:993:get_data_rates() declared: 51612 bps
00000074 ccid_usb.c:993:get_data_rates() declared: 103225 bps
00000072 ccid_usb.c:993:get_data_rates() declared: 206451 bps
00000072 ccid_usb.c:993:get_data_rates() declared: 412903 bps
00000073 ccid_usb.c:993:get_data_rates() declared: 154838 bps
00000070 ccid_usb.c:993:get_data_rates() declared: 258064 bps
00000073 ccid_usb.c:993:get_data_rates() declared: 7168 bps
00000072 ccid_usb.c:993:get_data_rates() declared: 14336 bps
00000071 ccid_usb.c:993:get_data_rates() declared: 28673 bps
00000072 ccid_usb.c:993:get_data_rates() declared: 57347 bps
00000094 ccid_usb.c:993:get_data_rates() declared: 114695 bps
00000076 ccid_usb.c:993:get_data_rates() declared: 229390 bps
00000072 ccid_usb.c:993:get_data_rates() declared: 143369 bps
00000386 ccid_usb.c:993:get_data_rates() declared: 8602 bps
00000082 ccid_usb.c:993:get_data_rates() declared: 17204 bps
00000073 ccid_usb.c:993:get_data_rates() declared: 34408 bps
00000072 ccid_usb.c:993:get_data_rates() declared: 68817 bps
00000072 ccid_usb.c:993:get_data_rates() declared: 137634 bps
00000071 ccid_usb.c:993:get_data_rates() declared: 275268 bps
00000109 ccid_usb.c:993:get_data_rates() declared: 5376 bps
00000076 ccid_usb.c:993:get_data_rates() declared: 64516 bps
00000072 ccid_usb.c:993:get_data_rates() declared: 107526 bps
00000071 ccid_usb.c:993:get_data_rates() declared: 6451 bps
00000071 ccid_usb.c:993:get_data_rates() declared: 77419 bps
00000072 ccid_usb.c:993:get_data_rates() declared: 8064 bps
00000072 ccid_usb.c:993:get_data_rates() declared: 16129 bps
00000071 ccid_usb.c:993:get_data_rates() declared: 32258 bps
00000071 ccid_usb.c:993:get_data_rates() declared: 96774 bps
00000072 ccid_usb.c:993:get_data_rates() declared: 161290 bps
00000242 ccid_usb.c:993:get_data_rates() declared: 3584 bps
00000110 ccid_usb.c:993:get_data_rates() declared: 71684 bps
00000117 ccid_usb.c:993:get_data_rates() declared: 4301 bps
00000072 ccid_usb.c:993:get_data_rates() declared: 2688 bps
00000073 ccid_usb.c:993:get_data_rates() declared: 53763 bps
00000072 ccid_usb.c:993:get_data_rates() declared: 3225 bps
00000071 ccid_usb.c:993:get_data_rates() declared: 38709 bps
00000072 ccid_usb.c:993:get_data_rates() declared: 4032 bps
00000072 ccid_usb.c:993:get_data_rates() declared: 48387 bps
00000073 ccid_usb.c:993:get_data_rates() declared: 80645 bps
00000072 ccid_usb.c:993:get_data_rates() declared: 2150 bps
00000071 ccid_usb.c:993:get_data_rates() declared: 2580 bps
00000073 ccid_usb.c:993:get_data_rates() declared: 5161 bps
00000071 ccid_usb.c:993:get_data_rates() declared: 10322 bps
00000099 ccid_usb.c:993:get_data_rates() declared: 20645 bps
00000074 ccid_usb.c:993:get_data_rates() declared: 41290 bps
00000071 ccid_usb.c:993:get_data_rates() declared: 82580 bps
00000072 ccid_usb.c:993:get_data_rates() declared: 30967 bps
00000266 ccid_usb.c:993:get_data_rates() declared: 7812 bps
00000081 ccid_usb.c:993:get_data_rates() declared: 15625 bps
00000105 ccid_usb.c:993:get_data_rates() declared: 31250 bps
00000072 ccid_usb.c:993:get_data_rates() declared: 62500 bps
00000071 ccid_usb.c:993:get_data_rates() declared: 125000 bps
00000072 ccid_usb.c:993:get_data_rates() declared: 250000 bps
00000109 ccid_usb.c:993:get_data_rates() declared: 93750 bps
00000074 ccid_usb.c:993:get_data_rates() declared: 156250 bps
00000071 ccid_usb.c:993:get_data_rates() declared: 9375 bps
00000071 ccid_usb.c:993:get_data_rates() declared: 18750 bps
00000071 ccid_usb.c:993:get_data_rates() declared: 37500 bps
00000071 ccid_usb.c:993:get_data_rates() declared: 75000 bps
00000070 ccid_usb.c:993:get_data_rates() declared: 150000 bps
00000070 ccid_usb.c:993:get_data_rates() declared: 300000 bps
00000072 ccid_usb.c:993:get_data_rates() declared: 112500 bps
00000072 ccid_usb.c:993:get_data_rates() declared: 187500 bps
00000071 ccid_usb.c:993:get_data_rates() declared: 5208 bps
00000071 ccid_usb.c:993:get_data_rates() declared: 10416 bps
00000071 ccid_usb.c:993:get_data_rates() declared: 20833 bps
00000071 ccid_usb.c:993:get_data_rates() declared: 41666 bps
00000096 ccid_usb.c:993:get_data_rates() declared: 83333 bps
00000261 ccid_usb.c:993:get_data_rates() declared: 166666 bps
00000074 ccid_usb.c:993:get_data_rates() declared: 104166 bps
00000072 ccid_usb.c:993:get_data_rates() declared: 6250 bps
00000070 ccid_usb.c:993:get_data_rates() declared: 12500 bps
00000072 ccid_usb.c:993:get_data_rates() declared: 25000 bps
00000071 ccid_usb.c:993:get_data_rates() declared: 50000 bps
00000070 ccid_usb.c:993:get_data_rates() declared: 100000 bps
00000064 ccid_usb.c:993:get_data_rates() declared: 200000 bps
00000065 ccid_usb.c:993:get_data_rates() declared: 3906 bps
00000064 ccid_usb.c:993:get_data_rates() declared: 46875 bps
00000091 ccid_usb.c:993:get_data_rates() declared: 78125 bps
00000067 ccid_usb.c:993:get_data_rates() declared: 4687 bps
00000066 ccid_usb.c:993:get_data_rates() declared: 56250 bps
00000065 ccid_usb.c:993:get_data_rates() declared: 5859 bps
00000065 ccid_usb.c:993:get_data_rates() declared: 11718 bps
00000064 ccid_usb.c:993:get_data_rates() declared: 23437 bps
00000063 ccid_usb.c:993:get_data_rates() declared: 70312 bps
00000065 ccid_usb.c:993:get_data_rates() declared: 117187 bps
00000067 ccid_usb.c:993:get_data_rates() declared: 2604 bps
00000065 ccid_usb.c:993:get_data_rates() declared: 52083 bps
00000065 ccid_usb.c:993:get_data_rates() declared: 3125 bps
00000063 ccid_usb.c:993:get_data_rates() declared: 1953 bps
00000064 ccid_usb.c:993:get_data_rates() declared: 39062 bps
00000064 ccid_usb.c:993:get_data_rates() declared: 2343 bps
00000065 ccid_usb.c:993:get_data_rates() declared: 28125 bps
00000085 ccid_usb.c:993:get_data_rates() declared: 2929 bps
00000219 ccid_usb.c:993:get_data_rates() declared: 35156 bps
00000074 ccid_usb.c:993:get_data_rates() declared: 58593 bps
00016844 ifdhandler.c:402:IFDHGetCapabilities() tag: 0xFB3, usb:076b/3021:libusb-1.0:3:4:0 (lun: 0)
00000122 readerfactory.c:296:RFAddReader() Using the reader polling thread
00004598 ifdhandler.c:402:IFDHGetCapabilities() tag: 0xFAE, usb:076b/3021:libusb-1.0:3:4:0 (lun: 0)
00000198 ifdhandler.c:490:IFDHGetCapabilities() Reader supports 1 slot(s)
00000281 readerfactory.c:1303:RFWaitForReaderInit() Waiting init for reader: OmniKey CardMan 3121 00 00
00000128 hotplug_libusb.c:421:HPEstablishUSBNotifications() Driver ifd-ccid.bundle does not support IFD_GENERATE_HOTPLUG. Using active polling instead.
00000215 hotplug_libusb.c:430:HPEstablishUSBNotifications() Polling forced every 1 second(s)
99999999 pcscdaemon.c:680:signal_trap() Received signal: 2
00000113 pcscdaemon.c:699:signal_trap() Preparing for suicide
00365739 hotplug_libusb.c:383:HPRescanUsbBus() Hotplug stopped
00634442 readerfactory.c:1256:RFCleanupReaders() entering cleaning function
00000098 readerfactory.c:1265:RFCleanupReaders() Stopping reader: OmniKey CardMan 3121 00 00
00000058 eventhandler.c:148:EHDestroyEventHandler() Stomping thread.
00000084 ifdhandler.c:402:IFDHGetCapabilities() tag: 0xFB1, usb:076b/3021:libusb-1.0:3:4:0 (lun: 0)
00000070 ifdhandler.c:402:IFDHGetCapabilities() tag: 0xFB2, usb:076b/3021:libusb-1.0:3:4:0 (lun: 0)
00000054 eventhandler.c:173:EHDestroyEventHandler() Request stoping of polling thread
00000054 ifdhandler.c:367:IFDHStopPolling() usb:076b/3021:libusb-1.0:3:4:0 (lun: 0)
00401136 eventhandler.c:469:EHStatusHandlerThread() Die
00000381 eventhandler.c:188:EHDestroyEventHandler() Thread stomped.
00000068 readerfactory.c:987:RFUnInitializeReader() Attempting shutdown of OmniKey CardMan 3121 00 00.
00000093 ifdhandler.c:294:IFDHCloseChannel() usb:076b/3021:libusb-1.0:3:4:0 (lun: 0)
00003492 readerfactory.c:863:RFUnloadReader() Unloading reader driver.
00000890 winscard_svc.c:130:ContextsDeinitialize() remaining threads: 0
00000150 pcscdaemon.c:629:at_exit() cleaning /var/run/pcscd
are these the latest drivers for omnikey ive tried to install but get the message not downgrading to 1.4.5
