PCTV tripleStick 292e
Eragon
Vu+ User+++
I too am very interested in this T2 USB tuner since the old 290e (AFAIK the only compatible T2 USB tuner) is now almost impossible to find at a reasonable price.
Moreover the 292e is also a DVB-C tuner and has an updated hardware.
mfinsv
I'm not sure if this is helpful, but I got this working on my enigma2pc install on Ubuntu 12.04.
First I upgraded to kernel 3.17 as described here
http://www.yourownlinux.com/2014/10/how-to-install-linux-kernel-3-17-stable-in-linux.html
https://github.com/Raider05/enigma2pc
http://blog.palosaari.fi/2014/04/naked-hardware-15-pctv-triplestick-292e.html
After that I installed enigma2pc openpli as described here
And at last I did the extract of dvb-demod-si2168-01.fw from the included cd as described here
At least this shows that the tripplestick 292e driver work on enigma 2 openpli, but I guess we need
to have kernel 3.17 on our Vu+ for it to work.
angelofsky1980
BlackHole Driver Specialist
As you see, I've fixed ALL LIVE LINKS you have posted.
About your question, we are working on the new (latest) driver set for Vu+ boxes in our spare/free time.
Karsta
It's supported (DVB-T2 at least) in kernel 3.16 by Antti Palosaari.
In kernel 3.17 it's like this:
http://www.noodls.com/view/CF55CF6E36620D6B1900BE242BC039267CCFC14A?4142xxx1414538766
Have you found any spare time yet?
angelofsky1980
Try with latest BH image (2.1.3)
angelofsky1980
Thanks, but I'm an OpenVix user. It has currently 3.13 kernel. I don't need it that badly (just yet) so I guess I have to wait for some updates.
You should try BH images with LATEST Linux DVB USB drivers .... we don't use kernel builtin drivers :)
Karsta
You should post the output of dmesg command ....
I ran dmesg before and after plugging the stick (in the front connector for being lazy) and diff'ed them:
:~$ diff ttu ttu2
--- ttu
+++ ttu2
@@ -1,5 +1,3 @@
-Bluetooth: HIDP socket layer initialized
-Key type dns_resolver registered
PM: CP0 COUNT/COMPARE frequency does not depend on divisor
EBI CS0: setting up NAND flash (primary)
NAND device: Manufacturer ID: 0xec, Chip ID: 0xd3 (Samsung NAND 1GiB 3,3V 8-bit)
@@ -262,3 +260,4 @@
ROLT
usb 3-1: new high-speed USB device number 2 using ehci-brcm
usb 3-1: USB disconnect, device number 2
+usb 3-1: new high-speed USB device number 3 using ehci-brcm
angelofsky1980
:~$ diff ttu ttu2
--- ttu
+++ ttu2
@@ -1,5 +1,3 @@
@@ -262,3 +260,4 @@
ROLT
Post also "lsusb" output please (with USB device connected)
Karsta
It's in use in another Linux box, but I guess this tells even more than the very limited "lsusb" in VU:
Bus 002 Device 103: ID 2013:025f PCTV Systems
w_scan tells:
"/dev/dvb/adapter1/frontend0 -> TERRESTRIAL "Silicon Labs Si2168": very good :))"
and lsusb -v:
Couldn't open device, some information will be missing
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 0 (Defined at Interface level)
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x2013 PCTV Systems
idProduct 0x025f
bcdDevice 1.00
iManufacturer 3
iProduct 1
iSerial 2
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 41
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 500mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 255 Vendor Specific Class
bInterfaceSubClass 0
bInterfaceProtocol 0
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x84 EP 4 IN
bmAttributes 1
Transfer Type Isochronous
Synch Type None
Usage Type Data
wMaxPacketSize 0x0000 1x 0 bytes
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 1
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
wMaxPacketSize 0x03ac 1x 940 bytes
bInterval 1
Karsta
Even some more from syslog (dmesg did not react on this 3.16.1 kernel machine??)
[172903.640209] usb 2-4.3: new high-speed USB device number 117 using ehci-pci
[172903.733086] usb 2-4.3: New USB device found, idVendor=2013, idProduct=025f
[172903.733092] usb 2-4.3: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[172903.733095] usb 2-4.3: Product: PCTV 292e
[172903.733097] usb 2-4.3: Manufacturer: PCTV
[172903.733100] usb 2-4.3: SerialNumber: 0011402519
[172903.733503] em28xx: New device PCTV PCTV 292e @ 480 Mbps (2013:025f, interface 0, class 0)
[172903.733508] em28xx: DVB interface 0 found: isoc
[172903.733565] em28xx: chip ID is em28178
[172905.695571] em28178 #0: EEPROM ID = 26 00 01 00, EEPROM hash = 0xca13f904
[172905.695576] em28178 #0: EEPROM info:
[172905.695578] em28178 #0: microcode start address = 0x0004, boot configuration = 0x01
[172905.702822] em28178 #0: AC97 audio (5 sample rates)
[172905.702825] em28178 #0: 500mA max power
[172905.702827] em28178 #0: Table at offset 0x27, strings=0x146a, 0x1888, 0x0a7e
[172905.702878] em28178 #0: Identified as PCTV tripleStick (292e) (card=94)
[172905.702881] em28178 #0: dvb set to isoc mode.
[172905.702962] em28178 #0: Binding DVB extension
checking bus 2, device 117: "/sys/devices/pci0000:00/0000:00:1d.7/usb2/2-4/2-4.3"
bus: 2, device: 117 was not an MTP device
[172905.711618] i2c i2c-6: Added multiplexed i2c bus 7
[172905.711623] si2168 6-0064: si2168: Silicon Labs Si2168 successfully attached
[172905.714067] si2157 7-0060: si2157: Silicon Labs Si2157 successfully attached
[172905.714076] DVB: registering new adapter (em28178 #0)
[172905.714081] usb 2-4.3: DVB: registering adapter 1 frontend 0 (Silicon Labs Si2168)...
[172905.714510] em28178 #0: DVB extension successfully initialized
[172905.714514] em28178 #0: Registering input extension
[172905.714822] Registered IR keymap rc-pinnacle-pctv-hd
[172905.714933] input: em28xx IR (em28178 #0) as /devices/pci0000:00/0000:00:1d.7/usb2/2-4/2-4.3/rc/rc0/input15
[172905.715016] rc0: em28xx IR (em28178 #0) as /devices/pci0000:00/0000:00:1d.7/usb2/2-4/2-4.3/rc/rc0
[172905.715448] em28178 #0: Input extension successfully initalized
