Yes, I have it set to auto start after 2 seconds of changing a channel.well for me, permenant time shift allows to rewind past the point once pause is used.
without the added plugin i could only rewind to the point of using the pause button.
are u saying that u can rewind past the point you pressed the pause button using the buit in timeshift?
Ok I have deleted the permanent timeshift all all works fine, but I am sure this never worked when I tried it prior to permanent timeshift, that's why I installed it lol.Yes, I have it set to auto start after 2 seconds of changing a channel.
So from 2 seconds after I switch channel it starts to work and I can use rewind then at any point, no need to press the pause button at all.
and PTS also doesn't work for me without the plugin. V1.0.0 works fine for me.Menu - Setup - System - User Interface - Automatically start timeshift after ...
I have just updated to 3.0.2 and still cannot see:
