Request Personal Backup Issues
jumbi
Hi All,
Thanks again for all the help!!!
I'm having an issue with my personal backup not working.
I had the Duo config'd with 1.7.3 and then did a personal backup, upgraded to 1.7.9 and then everything worked 100% perfect after the personal backkup restore.
I was having a few issues so decided to re-flash and then just use the personal backup as before but when I do the restore now it everything looks ok from the screen but the Duo just hangs at the starting GUI screen and there does not see to be any settings re-loaded.
I know this is a bit strange but if anyone has seen anything like this before and could help it would be great.
Cheers,
Jumbi
Hi All,
Cheers,
Jumbi
If you have a crashlog, put it here.
I think yout personal backup was to old to used in last 1.7.9 if you will be have on him only basic setup maybe will be work.
Im was something like you in past but in my changed no work only 2-3 function.
I rhink personal backup work good when is made 2-3 version before this whot you have now.
Hi Angelofsky1980/bogdanm..
Looks like it was my total mistake. I just needed to restart something.... doh!!! ;-)
I am very sorry to have taken up your time on this guys...
I'm getting close to a lovely 1.7.9 setup and when it just fine tuned I'l be making a full backup and then onto really playing around with the box!!!
Thanks again for the help....
Jumbi....
