Personal Backups 2.1.1. - 2.1.3
can we use Personal Backups from 2.1.1 onto 2.1.3 or not compatible or not recommended
thanks
Just used a backup from 2.1.2 on 2.1.3.
You will need to re-install any packages that you installed. (For me auto bouquets and Linux Addons)
After you flash the image you make a few selections and it will prompt you to use your backup. Very easy.
