Piatanje za Miru...
dane
Pozz prijatelju,
meni ne ide CrossEPG na ovom zadnjem BH 1.6... Sve sam uredno nastimo ali nema prikaza EPG-a.... gdje bi mogao biti problem? Mozda na Rytec Serveru???
Koji EPG ?
Koja vrsta EPG ,koji provider
i gdje skidas EPG,na USB stik,harddisk itd
Dakle daj punu informaciju
exyu krkadoni epg... skidam ga na usb stick.
Vrsta je XEPGDB. Probao sam i XMLTV ali nista mi ne pokazuje... na usb stiku vidim epg.dat.. al ne pokzuje mi
rezultate.
Taj epg nije uredu ja neznam zasto to bi trebao pitat Munju
ali koliko znam mozes sa BH EPG u image skidati isti EPG
exyu krkadoni epg od Munje koji radi
osim toga koliko znam radi i Rytec XMLTV za nase drzave.
Cini se da Rytec ne radi momentalno
tu ima isto problema .
Provjerit cu sta je
ok.. mirane hvala.... javi rezultat.
Svi problemi nastaju zbog toga sto crossEPG koristi drugaciji path za epg.dat od BH image
to ce biti fixirano u sljedecem image
do tada moras napraviti sljedece pa si prevedi
ali ne zaboravi sve napravis istek posto si konfigurisao crossEPG i onda vise ne ulazis u config od crossEPG
Info abt MHW2 providers in CrossEPG (DIGITAL+) ​
we have found​
an incompatibility between the crossepg paths and Black Hole epg paths.​
This problem will be fixed in the next release or image upgrade.​
In the meanwhile the problem can be solved editing enigma2 settings file.​
/etc/enigma2/settings​
but after the CrossEPG configuration in Setup Menu >>CrossEPG>>Configure>>USB Stick​
and BH Epg configuration in BlackHole Blue Panel (blue button) >>red button>>​
>>Red button>>path to save Epg File >>/media/usb/epg.dat​
if you using USB stick​
NOW​
Edit the following line in the settings file (/etc/enigma2/settings) if you using USB stick​
config.misc.epgcache_filename = /media/usb/crossepg/epg.dat​
and replace with
config.misc.epgcache_filename = /media/usb/epg.dat​
Now from telnet
Give the following commands​
init 4​
and after command
init 3​
Now you can use CrossEPG MHW2 providers.
I have test only with USB stick ,I think it's similar with hdd.​
Rgd MX​
poslije ovoga ce raditi ja mislim i Munjin EPG u crossEPG
pozz mirane.. uspio sam.. sad to sljaka..
daj mi samo molim te reci gdje u skin.xml-u mogu promjenitin boju epg-a... sad mi je sve u bjelom. Znaci izbor kanala nek ostane bijela boja a epg recimo u zutom ili plavom... thanks...
Miro, gdje mogu u skin.xml-u promjenut boju u colorServiceDescription??? nemogu naci....
O tome sam vec pisao na forumu u threadu o Beyonce 9
to add color you have to add this coding
colorServiceDescriptionSelected="#c9a100"
You can change color if you change color code c9a100
like this in skin section
<screen name="ChannelSelection"
<widget source="Title" render="Label" position="0,27" size="1280,40" zPosition="1" halign="center" font="Regular;30" foregroundColor="black" backgroundColor="#21e2e2e2" transparent="1"/>
<widget name="list" position="70,111" size="780,510" scrollbarMode="showOnDemand" foregroundColorServiceNotAvail="#666666"
colorServiceDescriptionSelected="#c9a100"serviceItemHeight="30" serviceNumberFont="Regular;22" serviceNameFont="Regular;24" serviceInfoFont="Regular;23" colorEventProgressbarBorderSelected="#ffffff" picServiceEventProgressbar="SkinFactory9P/pl.png" selectionPixmap="SkinFactory9P/menu/button780x30.png"
transparent="1"/>
Dakle u sekciji skina u skin.xml
dodati ako vec nema u liniju koja pocinje u ovoj sekciji sa <widget name="list"
boju odredjuje ovdje hex kod c9a100
na internetu mozes naci codove za mnoge boje.
Pa probaj
pozz mirane,
napravio sam kako si napisao.. ubacio u liniju ali imam nakon restarta zeleni ekran..... htejo sam ubacit u ovaj tvoj novi SF10 gold.... gdje grijesim???
Ili nisi koristio Linux editor ili nisi dobro ubacio
dodas samo ovo u liniju
sa razmakom u odnosu na ostalo u toj liniji
ovdje je to sve jedno ispod drugog u textu
ali u skin.xml je to samo jedna linija i tako treba i da ostane
<widget name="list" position="10,37" size="780,480" scrollbarMode="showOnDemand" foregroundColorServiceNotAvail="#666666" colorServiceDescriptionSelected="#c9a100"
serviceItemHeight="32" serviceNumberFont="Regular;22" serviceNameFont="Regular;24" serviceInfoFont="Regular;23" picServiceEventProgressbar="SkinFactory10/pl.png" selectionPixmap="SkinFactory10/menu/button780x30.png" transparent="1"/>
evo ti skin.xml
skinfactory 10 pa experimentisi sa bojom
Ubacena zuta ali se meni ne svidja zuta na plavoj podlozi
pa ti vidi.
uspio sam mirane... ali nije to bas sto sam ja htjeo.. u ovm slucaju epg pozuti samo ako skocim na taj kanal... ja bih htjeo da konstantno ostane zuto...
malo te zezam al eto...koka cu ako necu tebe...:-)))
koju bi ti preporucio boju...?? ipak si ti profesor za ove stvari..
jel primas mozda ucenike? :-))
Za promjenu boje kad kanal nije selektiran moras dodati jos ovo u istu liniju
colorServiceDescription="#c9a100"
Koja boja ja neznam zato sam i ostavio da bude bjela jer se ona najbolje cita na plavoj podlozi
Po mome ako vec zelis neku razliku onda bi ostavio da bude bijela kad je kanal izabran
(plava podloga bara) a da bude zuta kada nije
jer zuta izgleda dobro na crnoj podlozi.
Dakle morao bi izbrisati prvu izmjenu
a ostaviti samo ovu
To je vec tako u mom zip
