Picons AB3 ?
Hello,
Why picons of AB3 are not visible ?
No problem with those of Astra and Hotbird.
1 - What kind of STB, do you have?
2 - What image are you using?
3 - Where you put the picons, Flash. Usb, HDD?
4 - What kind of set picons are you using, too?
5 - Are any others picons visible, except, AB3 ones?
Best regards
- Vu+ Solo2
- BH 2.1.5
- Flash
- Picons used before on OpenPLi 4
- Yes, Astra 19°2
Thanks
- Vu+ Solo2
- BH 2.1.5
- Flash
- Yes, Astra 19°2
Thanks
Why don´t you use a usb pen key to set picons there.
If you use BH 2.1.5., with Matrix10 ( Full HD Skins ) ---> Use HALUS61 --> 220x132 transparent ones ---> Use a pen a usb pen key ---> mapped to /usb/media ---> create a folder on root of your usb key ( name it picon ) --> It will fit like this:
/usb/picon
Put all picons here, reboot and you´ll have all picons ( Of course you can download this picons from Blackhole Addons Feeds ).
If you want use the internal flash ( not the best way ), download from the forum HALUS61 picons ---> http://www.vuplus-community.net/boa...black-hole-team-only.19655/page-9#post-158905
and put the picons png files --> /usr/share/enigma2/picon
Reboot and that´s all!
