how do I make picons bigger when I down load them to my box from fron the online down load center from my duo2
MX fullHD skins, 220x132 size ones cant seem to find this one in the down load s in skins I'm using the latest black hole image
Hi
Picons has to fit for the used Skin some Skins supports bigger some smaller
there are Skins out that supports for example 400x170x32 than you have a
Skin that supports only 100x60x8 so its difficult to gave you the right answer
i use not a Matrix10 Skin therefore i can use 400x170x32
View attachment 27447 View attachment 27448 View attachment 27450
Hi
Did i say anything else?
and ask i for support ? no so take your Post and ..................
If you have read my post --> http://www.vuplus-community.net/board/threads/picons-bigger.29311/#post-214033, i was clear enough.
Those picons you are referring, are not the best ones for @Matrix10 FullHD skins ... only 220x132 size matchs it.
Other skins, rather than Matrix10, are not supported by our team, although you can use it at yours own consideration, and without any kind of support.
