Picons for BH 2.1.6
abouwissal
Hello
Thank you for helping me to install the picons on USB , and what is the appropriate measure for black hole image 2.1.6.1.
Thank you.
Hello
Thank you.
Dued to fullhd skin ( 1920x1080 ), the best to fit is 220x132 ---> check on forum for Halus61 picons ( transparent ones ), or download it by addons!
I've searched for it on forum but no luck, can you give me a link? Theres no 0.8W picons from Halus61 over addons.
yes i know about the Changes...as i use these sats myself but with skin and picons suited for 100x60size...
but if theres picons with wrong channelreferences ...change the channelreference by clicking on blue button Then on nr 2 on rcu..
and you can see the new reference on the channel that has changed and then edit the picon so it fits you.
