Picons issue
Mastercoolb
hi all,
Currently running bh2.1.3 and I dowloaded picons from the addon server. All was working until I installed meoboot. The image running in meoboot has the picons. But bh2.1.3 which is in flash has lost all picons. Tried downloading from server again but nothing happening.
Any ideas how to fix this please? Thx
hi all,
You have downloaded picons for USB ??
Hi, I have always downloaded and installed from the bh feeds.
Yes, but there are picons for flash and USB installation.
At the moment I'm not near the receiver
but I think it should be like this
Format USB stick FAT 32
Make 2 partitions one for Meoboot other for picone (USB)
Format partitions.
Mount USB stick with two partities
one for meoboot and other for USB mount
Install USB picons from BH server on USB partition.
Install Meoboot on other partition for meoboot.
Many thanks will give it a try this evening.
The fact that I have already set up the usb for meoboot, is it possible to install picons on the hard drive rather?
