Picons not displayed for HD Channels
redline99
Hello,
i have bh 1.7.2 and download green panel - yellow - addon manager - Picon Packages, but not work for HD channels.
Its empty.
I want to have nice Picons for 19,2 and 13E.
I tried using dreambox pocins but no look aswell
Please help
Best regards
Hi,
Do you use picon directory in your hdd or usb? if so, you have to verify this hdd directory, if not verify /usr/share/enigma2/picon(be careful, this option uses flash memroy?
I have Bh1.7.2 with vusolo and picons are nice for 19.2
Regards.
i use picon on USB Flash Drive, download from feed works into USB, i also get the Picons on some SD Channels but not on HD CHannels.
Missing a lot.
I restart Gui, redownload but it doesnt fix problem.
Also have problems with skin, when i download skin for my BH Version its not applied after download, still old skin.
If anyone has cool looking Pikons / Skins please let me know, im looking for it...
I have Vu+ Uno BH 1.7.2
Please help
thanks
1- For skins: You have to apply the new skin you just download. It's applied after download!!!
2- For picons, may be some picons are missing for your channels! Try other picons: google search for "picons 19.2"
Missing a lot.
Please help
thanks
Hi redline99,
After U dLoad the new skin,,,go to menu>setup>....then choose the skin U downloaded and press OK,,,,STB will reboot and U will have the skin U desire!
I uploaded a file with picons for 19.2,,,you may like!
Have fun w/BH!
The Problem is with the Settings i use
C@JTON E2 Dreambox Settings
They are great settings but apparently he uses different channel identifiers because all HD Channel Picons dont work :(
I tried with other settings and all work but i would like to use his settings
thanks for help
