Picons not showing
Miguelin
Hi all,
I just installed BH 2.1.7 in my new Duo2. All is working fine less showing the picons in Infobar and channel list (config activated).
I can see these picons in LCD and CollTV guide but not in Infobar and Channel list.
Do you have any idea about it?
Sent from my Nexus 6 using Tapatalk
Hi all,
1) - Where did you put your " picon files "?
2) - What skin with this image are you using?
Hi nunigaia. I am using BH 2.1.7 with its default skin. I create a soft link in /usr/share/enigma2/ called "picon" which points to a folder in a network drive.
Weird thing is that i can see these picons in CoolTV and LCD...
1) I don´t use a network hdd drive for this.
2) If you put your picons on your flash memory /usr/share/enigma2/picon they should appear normaly upon restart enigma or reboot.
3) It´s not recommend using a hdd ( leave it to your consideration, dued a constant hdd spinning ).
4) Better solution use as i do, and almost users, a usb pen drive to have your picons ... mapped as /media/usb ...
In this case, you can download halus61 picons 220x132 directly from the addons feeds without even the need to create the "picon" folder.
Hi nunigaia,
Just mapped a usb stick as media/usb, changed the soft link to this route, installed halus61 220x132...same results. I see these picons perfectly in Colltv and LCD but not in the infobar neither channel list. What is going wrong?
Regards
Hi nunigaia,
Regards
Have you unlinked the soft link you made?
If not unlink it ... delete the <picon> folder under /usr/share/enigma2/picon ... upon, reboot your stb...
Note: If you initialize your usb pen drive and mapped it, you don´t need to soft link any files or folders ...
1) Format it using fat32 ( on your pc ) or ext4 ( on duo2 ( in this case if you intend to use Open Multiboot too ... ))
2) Mapp it as /media/usb ... reboot
3) Download from the feeds halus61 picons ... it will download and unpack it to your /media/usb ... and will create the folder <picon> for you in it ( automatically ) ... reboot ... you don´t need nothing more!
To show picons on channel list:
Menu > Setup > System > Customize > Show picons in channel list: Yes
Just removed the soft link which i created. Now, I can see the picons in Infobar and channel list but not in LCD!
This is crazy!
Thanks nunigaia
I use the thread here as my problem is exactly the same.
I mapped USB pen drive as /media/usb/ and downloaded some halus61 picons in it, rebooted stb etc.... They are not visible in channels. Apparently because before USB mapping I downloaded halus61 (19E Astra) picons directly to stb. These are well visble! But I can't find where are the Astra picons I downloaded before, in order to delete them. No in /usr/share/enigma2. There is only the folder <piconlcd>. <picon> does not exist there at all. Where I have to search them? All downloaded halus61 files are in /media/usb/ folder but they are still not is use...
What I have to do?
(Vu+Duo2; BH 2.1.7;DarkSky skin)
