I have downloaded picons on a fat32 USB and all picons show fine, but when I want to record something on my HDD I get an error saying HDD not mounted. HDD has been operating great for over 2 years, works fine when I remove the USB though.
Press Blue>Blue and then the fourth voice: take a look if iyour Usb is mounted as /media /hdd if yes you must gange in /media/usb.
Afyer you must mount your HDD as /media/hdd
Remember that the picons in Usb should be includedt in the picon folder.
The rooth is /media/usb/picon/
I mounted the USB and confirmed HDD was already mounted so set up ok, but following this method the picons are not recognised. Currently using BH 2.1.7
