Picons when OBH is installed in HDD
AlexWilMac
Moderator
Hello, I installed the new 0.4 in the HDD by openmultboot.
I tried to use the picons either installing from the provided addon or manually copying into the /media/usb/picon folder but they are not shown. This means that that is not the right folder to point at.
What is the right one?
And why the normal procedure, through the addons menu, didn't succeed?
After I found another way to install picons (although not very updated and not the size I wanted) through some addons menu, I found them in the harddisk where two new folders had been created:
usr/share/enigma2/picon
and another one not related.
Then I finally was able to copy all my picons there and it worked.
Note that I had also to change the path into this new one in LCD4linux, previously manually set elsewhere.
what kind of picon did you copy there?
