Hi. How can i get lcd display to work after new insatall? I have i latest Open blackhole on my Vu+ Duo2
can someone tell me please...
Patn
Hi i have tried that but no picture there:-( what can i do next ?
Patn
Thanks. now the display working can you also tell me how i can get picons to work in the channel list also
Patn
Hi. agian i have done it, but it does not have no Picons entering :-( I use 0.8 W and 4.8 e which Picons can I use?
and where can i find them?
Regards
Patn.
Hi. i forgot, what size do I enter? and in which lane should I put those in?
so it will work?
Regards Patn.
Hi. sorry, i need to know where i put the files, example /usr/share/enigma2 ? and if there is one or two i need to install?
is there the same file for lcd and the channel list picon logo?
Regards Patn
It´s more simple and don´t fill up your flash memory.
Use instead of flash memory an USB Pendrive for handle picons.
If you want one of these days to use Open Multiboot ... initilialize it inside your STB ... Format as EXT4 FS ... and mount it as /media/usb
on the root of your usb media, create a folder named "picon" and give to it the attributes 755. ---> the destination folder will be as this: /media/usb/picon
Download the picons i said and upload with an ftp tool = DCC or Filezilla or VUcc, to this folder all your dowloaded picons.
Best regards
Hi, I made this steps, to put picons on USB, but still dont work, I have lcd4linux, and made this~
"Press <Menu >; <Setup>; <System>; <Customize>; <User interface>
On <User Interface>, change from <NO> to <YES> in " SHOW PICONS ON CHANNEL LIST"
And nothing happen, can you help me.
Vitor Fernandes
I now, I tell that I do the 2 things, the lcd4linux thing and the channellist thing.
Yes I have the root trace "/media/usb/picon
yes I put folders permissions 755, and icons permissions 644
So I am looking for an big wall, I dont know what to do.
Regards
Vitor Fernandes
Good morning,
I am not yet usind multiboot, and I'am usind BH 3.0.1 F and skin MX HQ 10XC, I send some print screens
Information
Menu of skin (it's for me the better skin)
And where the picon I want to see
and where
Best regards
Vitor Fernandes
Note: To handle picons from " /media/usb/picon ", your device has to be allways connected to your STB and mounted.
