Picture Center FS 3.63 or 3.62
sakisdvb
BH Lover
I have installed picturecenter FS 3.62 or 3.63 but it doesn't appear in green panel.
I have rebooted box but still is missing.
Any suggestions ?. :unsure:
Amongst the Latest 10 Uploads, in BH Addons Download Manager, there is currently the same Plugin mentioned above with V 3.87.
It also does not show up amongst the Plugins line-up after installation.
Any suggestions/help? Thks.
Reboot your box then press Menu > Plugins and then grab a screen shot of any errors.
Post your findings.
Downloaded and installed the Plugin.
The Box did the Restart Gui as usual.
Went to Menu>Plugins but found no trace of Plugin.
Rebooted and checked again in Menu>Plugins but no trace of Plugin again.
No errors found at all.
Simply the Plugin is not there.
I have not test with solo2 but with duo2 and BH 2.0.9
with file PictureCenter FS v3.87 from Plugins server
Plugin is installed without problems
and is located in the plugins and the green panel.
I too have BH 2.0.9 in Flash.
Maybe somebody using Solo2 who has tried to install the Plugin will give more feedback.
Ok
I have test with solo2
There are missing python-imaging
So first install manually python-imaging
You have to copy (FTP) file to /tmp
then
green button>>yellow>>Manually Install Ipk packages>OK (install python-imaging)
Then install
file PictureCenter FS v3.87 from Plugins server with addons manager
thanks for plugin it works fine but still have some bugs. a lot of green screen when rotating in slideshow mode and when learning from help button all functions of the plugin.
this python-imaging, what is it's purpose?
i installed it to have picture center plugin, i have bh 2.0.5
