Picture in picture
eric91970
Hi,
Just loaded the latest Blackhole 2.0.2 on my new Solo2, can someone point me in the right direction as to where you can turn the picture in picture function on.
Thanks in advance,
eric91970
There are two way to do it:
- Menu extensions (long press of blue button) > Activate PiP;
- Select a channel with arrow up or arrow down button, then press Menu button and select Activate PiP.
To disactivate PiP function: Menu extensions (long press of blue button) > Disable PiP
