Hi all,
I have problem reproducing 4:3 ratio video on a 16:9 display using media player (latest available image), it streach the video to 16:9.
No problem viewing normal SAT 4:3 channel.
Any idea?
Thanks a lot
I presume you have the 2 ones mentioned on the above post ... you can give a try to MEDIAPLAYER2 ... and let the base configuration AV settings for SAT viewing, that matchs you preferences.Sorry...
Black Hole Vu+ SoloSE 2.1.7 on a Vu+ SoloSE V2 Box...
<cut>
Installed, up&running.
I have only a problem with subtitles, I search if already happened to other.
Thanks again!
What´s up with subtitles?
They are working flawlessly for me!
they are working also for me, but not with every sub I have tested (I'm testing the entire image)
with some sub (*.sub) I'm getting --> Cannot load sub, Invalid path
with some sub (*.srt) I'm getting --> Cannot parse........
with some sub (*.srt) It's working fine
I have found a really small behavioural thing asking for plugins menu, if you call plugin with green button instead of menu-->plugin you have not the plugins in the same order (btw in the second case "Media Player 2" is on the top...
Another small thing is, if you set Media Player 2 to be shown on "Main Menu" than you can find it is called "Media Player" without "2", so you have "Media Player" displayed twice... but... again, really small thing...
Regards
Regards
I know that, this is hapening on Blackhole images, cause in Open Blackhole the default Mediaplayer only appear on MENU if setted to do it.
But i think that it goes, to the most of your expectations, and solve your severall issues.
