Ping slow response with Vu+Duo4K inside telnet
L@Zar0
Hi,
I have a little curiosity. When I get into my Vu+Duo4k (with BH3.0.9 updated to last version .K), I access to it with telnet, and somehow I receive a lag of time (maybe 1-2 seconds) doing a ping (for example). I've seen this accessing to the repositories of BH also.
The ping has this slow response time (the first time, after the first package received, the rest of packages are working well) in any case. I can do a:
ping www.google.es
and have this result.
How can avoid this lapse of 1-2 seconds from doing the ping until I receive some answer (or ACK)?
I have connected by Ethernet the Vu+ to the router. I have tested DHCP and STATIC ip config. In any case the result is the same. I think the problem comes by another side.
Thanks in advance.
Regards.
PD: If I telnet to the router and make the same ping, the response is inmediate. So the issue comes from the Vu+. I will try to test with WiFi connection.
More testing...
If I update /etc/hosts file and assign the ip address to the url format, for example this entry:
216.58.211.35 www.google.es
the ping is inmediate. How is this?
I have a notebook and the DNS resolves well the urls, it has no lags...
