greatguy112
Hi , i just have a small issue used the search button but cant find the perfect solution,i have to cables from separate dishes I have one cable on a motor to tuner A, and another to a fixed dished to 28E on tuner B, tuner A setup Advanced to motor, tuner B connected as simple, single lnb fixed to 28E. Now my problem is anytime i activate PIP , it shows a small box with the current channel I'm as well, ( that's fine) now when i change channel i get the new channel on the big screen and the old channel still remains in the small box as long as its on the same sat , now the issue is when i change channel to another satellite, the small box disappears and only have the main screen. i want to be able to watch 2 satellites at the same time. Any ideas will be very much appreciated
