PIP very small if called from channel list
AlexWilMac
Moderator
I've always activated PIP through the long blue press and then blue again and this works fine.
Now I tried to do differently, starting from the services list, choosing a channel, then MENU, and then "Play as PIP". This would immediately give me the desired channel in the PIP window. But using this procedure the window appears on the top-left corner and it's really, really small. I can obviously resize and move it, but the next time it gets back to the smallest size and position.
With the other procedure, the windows is correctly on the top-right and the size I previously set.
