Pip where it is
Here puts
Características VU+ ZERO
noviembre 25, 2014 by admin | Filed in NOTICIAS, RECEPTORES | No comments
Vu+ Zero es una solución ideal como segundo receptor Vu +
Vu + ZERO es una opción inteligente para los que utilizan modelos Vu + como: receptor SOLO2 y receptor DUO2 HDD integrado. Supongamos que usted utiliza Vu+Zero en su habitación. Una vez conectado a la red doméstica, puede reproducir contenidos multimedia almacenados en el receptor DUO2 y el receptor SOLO2 en la sala de estar.
Vu+ZERO es sin duda la solución más idónea para su segundo decodificador.
Entre las características técnicas que posee el Vu+Zero están las siguientes:
  • CPU (MIPS) 742MHz
  • 512 MB Ram
  • 256 MB de flash (NAND)
  • 1x sintonizador DVB-S2
  • 1x Tarjeta Inteligente
  • 2x USB
  • 1x RS232
  • 1x LAN (100 Mbit)
  • 1x HDMI
  • 1x S / PDIF
  • 1x vídeo compuesto
  • 1x Audio analógico (Stereo Jack)
  • PiP (Picture in Picture)
  • HDTV
  • Pantalla LED
comprar Vu+Zero
http://www.padredefamilia.com/
Edit: No live links allowed.
I'm sorry for you, that seller deceived you!:(
You are legitimate to ask him for a reimbursement.
And in the future always check only the manufacturer specifications!
Here is official
Please provide the source where that summary appears.
"Official" is only true if the information come directly from the Vu+ web sites, all other sources are NOT OFFICIAL, IRRELEVANT, and possibly FAKE.;)
http://openspa.info/threads/vu-zero.31673/
This is the source
OpenSPA: of course that source (a users forum!) cannot be considered reliable.
The typographic font used in the table is very rough and clearly not Vu+ original...;)
As you can see, the people that manually compiled that summary ERRONEOUSLY SWAPPED these 2 contiguous values for the Zero:
3D = No (absolutely wrong, all receivers can output 3D video signals!)
PiP = Yes
while in the official Vu+ summary:
3D = Yes
PiP = No
So, you could ask for a reimboursement to the author of that deceiving summary...:idea:
I have already posted the Vu+ official source:
http://www.vuplus.com/sub/sub0102.php
