PIP
ifearnobeer
I have a vu+ solo2 both tuners are fed through a static dish with 2 lnb outputs one in tuner A and the other in tuner B.i'm running blackhole 2.2.1.when i select pip through blue button long press,i get the same channel on both screens.I then change the channel and the pip insert stays the same but the main screen where the new channel was selected goes black.Both tuners are configured exactly the same with siple/single/28.2/no.Is there a tuner setup issue or am i doing something wrong.Thanks for any advice.
Post here the full configuration of both tuners (to save time you could also post only the 2 screenshoots)
Thanks for your help,problem now solved. pip will work if 2 fta channels are selcted.If i select a non fta channel, select pip and then choose a fta channel that also works,but if i select a fta for the insert and then a non fta for the main screen then that will show a blank main screen and a picture in the insert.It wont show 2 non fta channels.
