PIP
Oakenholt
Hi, how do you disable pip in 1.7.8. I have tried long press on blue button
and this brings up media player. Thanks.
Then you have installed something that changed buttons function .
Try with Help to find if possible to disable PIP .Im not sure.
Hello again, There is no 'view extensions' when pressing the help button
This just shows what each button does on the remote.
PIP works perfectly on all VU+ boxes but only as long it is SD. In the case of HD and also MP4 it may work showing strobing or not at all.
This is a HW restriction. Blue long press normally brings up the menu to enable/disable/move/swap PIP with 1.7.8 BH.
Only the coming SOLO2 and DUO2 promise full support of PIP without any restrictions.
I have found this option and it works. menu/setup/system/customize... setup mode should be set to expert, scroll to bottom of options and you will find
'behavior of 0 (zero) key in pip-mode'. set this to stop pip.....Done.
