I have a vu solo se buy, and it is whit open pli.
so i download this image VTi 9.0 for my box. format my usb to fat32 and copy the folder to usb but my box don't flash this image. i try whit all maps, and vusolo map only everythimg. i donwload another image and still wont flash. can someone help me out please?
thanks.
Unfortunately the Ask for Camd Support is not allowed here
and no it´s not normal that the Channel Search take that long.
Have you set up your Sat ( i suggest that you use Sat ) config right ?
located in :
Menu/Setup/Service Searching/Tuner configuration
i also suggest you have your Box on the Internet if yes
try to use a Settings File from the BlackHole Feed by pressing :
Green/Yellow/Online Feeds Settings Update
choose that one which is for your needs
Okey. I'm very sorry about my wrong quistion. I really happy that there is help. Now the scan is 23% and 393 channels found. . In that feeds settings update everything is empty. I looking at google and download a map blackhole ****2.2.1 ipk or something and putnin tmp i think. Thanjs fot helping me out.
Than you are not connected to the Internet ?
Put the File to /tmp is right
press Green/Yellow/Manual Install Ipk packages
choose the File you put to /tmp
If the File is "good" Reboot you Box than press Blue
Okey thanks. I have the box on LAN internet. I have put that file in the tmp folder. The channel search is now 54%and 2600 channels. I have to be calm. Thanks a lot for the help
