please help memmory
roble
Mem 111568k, 29852k Free, ok shrd 412k buff, 47676k cached
and keep changing too
is my memmory is full is oky
i have problem with my port keep blocking when i reboot my box
thank you angelofsky for reply
is there way to load all image to media/usb or media/hdd and run from there
so i can get vu+plus more space in ram
No,You can not use all images on some media like a hdd or usb. You can use BH in flash and other images via meoboot from USB (DUO&SOLO).
how i do that
becouse my ram is ful so i would like to lower space i have done media/hdd and media/usb
but my ram in 97 in use
You will not make any about Your RAM if You make multiboot.
For decrease used RAM stop to use EPG(crosepg or intewrnal) and use just plugins which You need. Your RAM in that situation will be from 60-80% max.
Also I use LSK free memory plugins and it work solid. You can find it in section vu+plugins.
