please help
Mohammedabdu
I f I choose radio mode in vu ultimo how to remove radio channel list in black hole2.0.1 if i press exit it go to tv please help how to listen to radio without the list.
In the standard Radio mode you cannot remove channel list.
But you can use Alternative radio mode
You have to first in the System Menu >> Customise >>
Setup mode (if you've not) enable Setup mode Expert (if necessary reboot)
and after you have to in the same menu Customise set >> Alternative radio mode >> Yes
Green Button OK
Now you have standard OSD in radio mode
you can use OK button for OSD the same as you use in TV Mode
Green Button OK
Thank you for help it is successful.
