please help
noornoor
Hello
I own device vu duo2
There is a picture of Original
The device does not accept any image only original images
Please Help
On Duo2 work other images made by teams too.
Maybe you doung soemthing wrong when yoiy can push to box other image.
You look to your pendrive or you upload good version image to your box ?
This device information
And tried several times to download a new image but the machine does not accept any form only original
How can the installation image BlackHole-2.0.9-
Don't try flashing BH from a pendrive connected to the front USB while you also have another USB pendrive or HDD connected to the rear USB port!!!
Also check:
you have downloaded the correct Duo2 BH image
you have formatted the pendrive with FAT32
you have correctly extracted the image on the pendrive so it contains the "vuplus" folder in its root
1. using a fresh formated pendrive as @Eragon said, and make sure there is no any other file in the pendrive.
2. extract the downloaded image (your pc will detect what is the best software to extract the image file) as @Eragon said. COPY all Folders and files to the pendrive.
It should work. Good Luck!
And is good used old pendrive with small space.
All this new pendrive more 4gb no work good with update.
