Please help
lex7791
Hello everyone Good day!!!!!!!!!!!!!!!!!
I just want to put ONLY hispasat 30w sattelite channels in my vu duo2 bh 305 for my own reasons.
Is it possible?
I know it sounds crazy but i want to do it
I want to put this sattelite Separately
Thank you very much!!!!!!!!!!!!!!
You can either do a manual scan, of the frequencies you want to scan in, or do a blind scan, of 30W.
It would help if you could please describe your dish set up, and how you have your tuners configured.
Thank you Mod
But i want a separate channel list of hispasat 30w like ipk for example....how to put..
I have motor but the motor cant auto search 30w.i want to put manually channels so when i press one channel ,,,i can search then for hispasat 30w
Sorry for this method but i use to do it years ago.This is my method
Please can you send me separately channel list for 30w for bh 305 vu duo2?
Please?
Sorry for my English!!!!!!!!
Thank you!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
In Linux-based images you should take advantage of the concept of BOUQUET.
This is simply a group of channels, a list where you can put whatever channel you like, terrestrial or sat. It's not like in traditional decoders where you have all your thousands of channels listed together.
So, in your case, create a bouquet named as you like and put there all the channels from this satellite.
Actually, in your case this is almost useless because, if you press UP or DOWN and then the GREEN button, you'll be prompted with all your satellites (and terrestrial).
The easiest method is to set up a new Bouquet, for 30W, and copy all the channels into that bouquet.
Use Dreamboxedit, to copy your channels, from your receiver, set up a bouquet, and copy them over.
Download dreamboxedit, onto your PC:
http://www.vuplus-community.net/board/forums/vu-tools-settings.10/
Place a new folder, on your PC desktop, and name it settings (default name, and location, for saving your channel list)
Start up dreamboxedit, click on Tools, at the top, and Options.
Enter your receivers IP address, test the connection, and if it's working click the save option.
Go to File, and click Fast FTP Download.
Once your list had loaded, go to the All Satellites drop down box and select Hispasat 30W.
You should now have a list of Data, TV, and Radio channels, on 30W, which you can copy over into your 30W Bouquet.
If you haven't got a 30W Bouquet, right mouse click, in the panel labelled TV User Bouquets, far right hand side, and click the insert new Bouquet option.
