PlexDVR Funktion instalieren auf VU+ Solo 4k
Silbvogel
Hallo!
Wie kann ich das Plugin PlexDVR / PlexDVRAPI / HRTunerProxy installieren? Mit dem Forum
https://forums.plex.tv/discussion/274004/enigma2-support-for-plex-dvr-livetv/p1
komme ich nicht zurecht. Dort sind Beschreibungen die immer wieder dort enden das das Plugin nicht funktioniert. Liegt das am BlackHole Image? Muss da eine spezielle Version installiert werden?
Gibt es da eine. ipk Installation Datei die ich einfach nach installieren?
Ich danke für eure Infos!
Hier noch einen auszug des Plex Forum!
PlexDVR Setup.
From OpenVix build 5.0.015 a new plugin is available and is coded for use with Plex DVR/LiveTV, download here http://www.openvix.co.uk/index.php/downloads/ , other teams also have support.
This will allow you to use Plex's DVR/LiveTV system to record shows from your E2 box directly into your Plex library, and also view LiveTV! on your Android / IOS devices. The EPG system in Plex is powered by Gracenote.
PlexDVR/LiveTV! is ONLY available to PLEX PASS members at the moment and you must use version 1.7.2 or above https://www.plex.tv/features/dvr/
I have attached a quick setup guide.
if your chosen image does not have support, ask your chosen image coders to contact me via PM @andyblac1974 here, and i will gladly help them with the necessary code.
Version 1.3:
allow user choice of what tuner type to setup.
Major recode of plugin to Version 2.0:
1: no need for /www folders anymore
2: hidden bouquets are now also hidden from Plex. (for example when hiding sections in ABM)
3: channel list is always up to date, for example, if you send a new channel list to the box, plex will see the changes without any user intervention (from PlexDVRAPI plugin).
4: the data files are now stored in /etc/enigma2, so they can be easily backed-up/restored.
wait for your team image to build or download from the source ink in my signature and copy the files to your box in /usr/lib//enigma2/python/Plugins/SystemPlugins/PlexDVRAPI
