plugin aspectratio
Does anybody know what's going wrong with my vu box it's just stuck on starting with no picture on the tv I've tried everything I've reset the box unplugged everything I don't no what to do need help please
Sent from my iPad using Tapatalk
Your message is off topic in this thread.:(
Please ask in the appropriate forum section relative to the Vu+ model you own.
HDMI video output signal has a fixed aspect ratio of 16:9, as for specifications.
When the received video signal is in 4:3 format and not in native 16:9, the box's HDMI settings allow you to automatically:
- enlarge (i.e stretch) the original 4:3 image to fill the 16:9 screen
- create a boxed 16:9 image adding 2 side black bars to the original 4:3 image
As for HDMI specifications, no other options could exist that can be applied automatically. For this reason such a plugin doesn't exist.
If you need to change the aspect ratio in some other way, you should check the available image format or zoom options of your TV set.
