Plugin for pasword reset E2
radja
password cracker/resetter ( John Plugin by gutemine )
copy the IPK to a usb stick, put usb stick in 800 and do a manual install
select the "john" plugin from the plugins list and then press the Yellow button to clear the root password.
kopiraj ovo sa PC-a na USB stik i zatim ubaci u usb ulaz drima.
Manuelno instaliraj.
Nakon toga kroz listu plugina udji u John plugin i stisni zutu tipku za reset.
To je to.
Послато са Lenovo A536 користећи Тапаток 2
merhaba arkadaşlar benım cihazı vu ultimo4k şifre kırıcı / resetter
pasif sıfırlama E2 için eklenti
vu ultimo 4k ya nasıl yükleyeceyiz teşekkürler.
Only English in this section because this is the International one. As said to other turkish people just a few days ago, you have your Turkish section to post in.
Last warning
I have already warned you to use the Turkish section of the forum.
Or write English.
Son uyarı
Forumun Türkçe bölümünü kullanmanız için sizi uyarmıştım.
Ya da ingilizce yaz.
ello friends my device vu ultimo4k password breaker /
Reset passive reset plug for E2
vu how to install ultimo 4k or thanks.
To je to.
How do you install manually on CloudIbox 2 Plus?
Just delete this thread the Cloudbox is a Vu+ clone and it has no place here.
Those China Clones comes with a dm password and people think they need to hack them ;)
