Plugin for zooming picture
Saf
Hello!
Is here plugin for zooming picture, when watching movie in 21:9 format (actually 16:9, but letterboxed 21:9, black stripes at the top and bottom)) TV connected to HDMI. Switching in AV settings not working, because HDMI is native 16:9, and movies format is 16:9 too (with black strips).
Thanks!
Hi Saf
If you use enhanced movie center, you can remove the stripes!
How:
download enhanced movie center 3.0 ----> and install it ( restart enigma if necessary )
download enhanced movie center 3.7 beta ----> and install it ( restart enigma if necessary )
Run on plugins --> enhanced movie center config as you wish
Upon configured --> Start enhanced movie center ( player )
Go to the movie you want play ---> Press OK for playing it ---> pause the movie ---> Menu ---> Setuo ---> System ---> Av Settings ---> on 16:9 change from LetterBox - to JustScale --> play and enjoy the movie
But in this way you'd cut off the 2 sides of the image...
But i´ve tested with a 16:9 movie with blackstripes up and down ( letterbox ), and if i change it for just scale ( that i have always , not for movies, but to watch SAT or Cable ), it will full the entire screen, but i don´t like the image, cause are anamorphic, distorced, stretched.
