Plugins
John Bailey
Think I may have inadvertantly deleted something in the FTP plugin panel.
Now all my added plugins have disappeared from the BH Green Panel, yet are still listed in FTP plugins-extensions.
Can anyone help, and tell me how I can restore these.
Also I have noticed that in Main Menu- Backup Menu is completely blank?
Any help would be appreciated,
Regards,
John
Regards,
John
I really don't know what could be, i'm afraid you should reflash.
Or if you still see plugin trough ftp, you can try to reboot, but i don't think you can solve.
Hi Tamaki,
Ended up doing a reflash which solved the problem.
Thank you very much for you advise, it is much appreciated.
Keep up the good work.
Best Regards,
John
